Thread: trying to fix stuff
Results 1 to 6 of 6
undecided trying to fix stuff 04-11-2011, 06:37 PM
taman86 Re: trying to fix stuff 04-11-2011, 07:44 PM
undecided Re: trying to fix stuff 04-11-2011, 07:45 PM
undecided Re: trying to fix stuff 04-11-2011, 10:11 PM
Fivefingerdeathpunch Re: trying to fix stuff 04-11-2011, 10:17 PM
taman86 Re: trying to fix stuff 04-11-2011, 10:38 PM
  1. #1 trying to fix stuff
    GT Level Member undecided's Avatar
    taylors falls MN
    hey its been quite some time i been on here so hello again
    i am having a weird engine temp problem and a misfire issue that is probally a maf sensor or coil pack and i was wondering what you guys think
    the car has speed daddy headers (horrible dont buy them the flex pipe went bad asap so i got an awesome exhaust leak) colder plugs and a ported sc
    the engine warms up really quick and will go up to the danger zone if sitting still for too long. i tried replacing the thermostat and no luck there. as long as im moving it will sit at about 190. dunno if this is normal with these cars because i have no one else to compare to but from what i have learned in the hot rod world i know the temp shouldnt be jumping around like that.
    now the misfiring thing is a random occurance that only happens when i have been driving for a while or beating on the car ALOT. when this happens i smell a large amount of unburnt fuel so its not fuel cut meaning its ignition. i replaced plugs and wires just this winter. so i think maybe coil pack. but the maf sensor is really sketchy as well i can pull it apart and look at the chip of the sensor and the previous owner tried to rtv this back together so im planning to buy a new one.
    also the traction control crap can i remove it? the light says its off 24/7 but its definately on
    im trying to fix the car up since it was my first car i ever bought (yeps its been running strong for 5 years now) and i would like my dd not to be an anti-poon
    1998 white grand prix gtp - speed daddy headers & ported supercharger
    1982 z28 Camaro - all original with only 80k miles and rust free - slow as heck
  2. #2 Re: trying to fix stuff
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    when i had my 2000 t/a i started having an overheat problem and i couldnt figure it out for the life of me. replaced the radiator cap, flushed the system, replaced the t stat, and checked the fans and seemed to be working fine. so i bit the bullet and took it to a shop, and guess what, my high speed fans werent working so at temps above 210 i had no cooling fans, just my low speed fans. maybe check those out, if not then maybe you have clog in your system.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  3. #3 Re: trying to fix stuff
    taylors falls MN
    i will try that this weekend thanks
  4. #4 Re: trying to fix stuff
    taylors falls MN
    figured it out. bad temp sensor
  5. #5 Re: trying to fix stuff
    There is a fix for your headers problem. Because many of us now know of the issue with the flex pipe and how the simple design fails.
    You gotta buy a 3in flex from ZZP and weld it in and that will solve the problem.
  6. #6 Re: trying to fix stuff
    Nov 2010
    south east AZ
    nice
    01 T/A WS6-SOLD
  1. New stuff!
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-13-2010, 11:50 PM
  2. Please Help Gas Stuff
    Last Post: 07-28-2008, 11:46 PM
  3. My New Stuff
    By GTPluv in forum Off Topic Discussion
    Last Post: 06-26-2008, 03:23 AM
