Thread: 2005 GT Turn signal issue.
Results 1 to 5 of 5
  1. #1 2005 GT Turn signal issue.
    Apr 2011
    Austin Texas
    Before I start I would like to say...Hello. Also i searched the site for the answer....could not find it. Today the Turn signal on the dash started blinking really fast. Also if the fog lamps were OFF only the right driving lamp would work. If the fog lamps were ON then they both worked, yet the blinker wouldn't. I changed the bulb and still have the same issue. Has anyone had this issue before. I'm at my wits end here.
  2. #2 Re: 2005 GT Turn signal issue.
    Apr 2011
    Austin Texas
    Anyone?
  3. #3 Re: 2005 GT Turn signal issue.
    SE Level Member Jackd90's Avatar
    Chicago
    If the blinker is flashing really fast, its usually a burnt out bulb.. did you change/check both front and rear turn signal bulbs?
    Open Cone Intake, 180° Tstat, Autolite 605 Coppers, Autolite 7mm wires (will upgrade soon), Muffler delete (headers soon)
  4. #4 Re: 2005 GT Turn signal issue.
    Apr 2011
    Austin Texas
    I replaced the bulb.....pretty sure its the socket.
    .....smells like burnt plastic.
  5. #5 Re: 2005 GT Turn signal issue.
    Chicago
    Alright.. which bulb did you change? What socket are you talking about (front left/right turn signal, dash blinker light, rear left/right turn signal, left/right fog light)? You need to be more specific with the problem.
  1. turn signal issue please help if you can.
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 12-08-2011, 09:36 PM
  2. turn signal help
    By sUpErClEaNbLaCkMaChInE in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2011, 08:09 PM
  3. Turn signal problem...
    By Chris in forum General Tech Discussion
    Last Post: 04-28-2010, 03:43 PM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
  5. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
