Thread: A/C control
Results 1 to 13 of 13
  1. #1 Re: A/C control
    GTP Level Member
    springfield IL
    if you take the glove box out you can see that door.
    hit the recirculation button and that door should close.
    Is this on the 97-03 models..??
  2. #2 Re: A/C control
    Quote Originally Posted by tc300 View Post
    yes, all cars really.
    its not that the fan speeds up, but when you hit recirculate that door closes, cutting off the fresh air, the fan is now in a sealed environment and blows harder.
    the recirculate button, is the same thing as setting a ford to max a/c.
  1. control arm over haul....
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 09-04-2011, 02:00 PM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. a/c control
    By stanggreg90 in forum General Tech Discussion
    Last Post: 07-27-2009, 10:07 PM
  5. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
