Thread: Oil warning light
Results 1 to 8 of 8
  1. #1 Oil warning light
    SE Level Member Skrappi69's Avatar
    USA
    99 Grand Prix- Oil light has been intermittently coming on even though the level is good. Happens at low and high RPM's. Any ideas?
    Thanks!
  2. #2 Re: Oil warning light
    Akron Ohio
    When that on you motors toast. Oil pump?
  3. #3 Re: Oil warning light
    Probably just the sending unit has taken a sh1t.
  4. #4 Re: Oil warning light
    id slap a oil pressure gauge on it just to see what the oil pressure is, the sensor is a 12 dollar fix.
  5. #5 Re: Oil warning light
    Which light?
    There are two lights on some of the W bodies. One is oil level and the other is oil pressure.
  6. #6 Re: Oil warning light
    USA
    It is the Oil Level warning light. It comes on intermittently. I checked the oil level and it is good. The temp gauge hovers around 160. The motor runs strong. No knocking or smoke or anything like that.
    I have not seen an indicator come on called Oil Pressure. Just the Oil Level.
    Should I have the oil pressure on it tested? Does a shop do that or can I buy an over the counter pressure gauge at Kragen's or Napa or someplace like that?
    Or can I just go with the sensor? Where is that located on a 99 GP non turbo?
    Thanks.
  7. #7 Re: Oil warning light
    If you checked the level and it's at the right area, the sensor is likely going bad. The oil level sensor is located on the side of the oil pan that faces the front of the car. I'd suggest swapping it out or checking the wiring at your next oil change or when it drives you nuts.
  8. #8 Re: Oil warning light
    USA
    BIllBoost37 - thanks. I'll give that a try.
  1. Brake Warning Light
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2011, 06:53 PM
  2. Check gauges, and low gas warning light problem
    By STE2400 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:09 AM
  3. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
