Thread: OLM Reset
Results 1 to 4 of 4
  1. #1 OLM Reset
    Apr 2011
    Chicago, IL
    I have an 07 GT with the 5 button DIC.
    Had the oil changed at the beginning of winter at the dealer because I had some other work done at the same time.
    Had the oil changed again at a local shop a month ago and the tech said "Everythings good, but I can't reset the oil monitor". For the first four years I have had to the car, resetting the Oil Life Monitor was as easy as just using the reset button on the DIC.
    Tried resetting it myself every which way--engine running, not running, press hold for more than 10 seconds--nothing would reset it. Reset button works fine because I am able to reset the MPG, Trip Odometers, etc.
    Finally, in doing some research here, was reminded of the gas pedal pump reset. That did it and the OLM is reset.
    But I was wondering if the dealer is able to do something that locks out the OLM reset from the DIC? Anything else I can look at.
    It's not a big deal since I can get it to reset and it won't be bugging me to change oil soon, but I just don't like it when simple things don't work. Makes me worry that something else is going on behind the scenes that will cause problems down the line.
    Thanks,
    ---Matt
  2. #2 Re: OLM Reset
    May 2011
    mpls
    i am having the same issue. what did you do to get it off??
  3. #3 Re: OLM Reset
    Apr 2011
    Chicago, IL
    Quote Originally Posted by jrbergy View Post
    Turn the ignition to "on" without starting the engine. Pump the gas pedal to the floor three times in 5 seconds, iirc.
  4. #4 Re: OLM Reset
    Quote Originally Posted by mmayer View Post
    100% correct, just about all GM cars are like this.
  1. computer reset itself???
    By GTPgurl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2011, 04:35 PM
  2. How to reset the TPMS
    By redbandit12 in forum Tires & Wheels
    Last Post: 12-02-2010, 10:50 AM
  3. zzp 1.0 pcm- Question about reset
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 07-24-2010, 10:02 AM
  4. reset abs
    By 99gpse in forum Off Topic Discussion
    Last Post: 04-11-2009, 09:02 PM
  5. how do i reset the theftlock???
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2008, 03:08 PM
