Thread: injector issue
Results 1 to 7 of 7
gtpinsc injector issue 04-02-2011, 09:30 AM
cerick08GP Re: injector issue 04-02-2011, 11:57 AM
gtpinsc Re: injector issue 04-02-2011, 12:53 PM
01gpgt01 Re: injector issue 04-02-2011, 05:11 PM
gtpinsc Re: injector issue 04-02-2011, 05:38 PM
cerick08GP Re: injector issue 04-02-2011, 09:57 PM
dsmuts Re: injector issue 04-02-2011, 05:38 PM
  1. #1 injector issue
    Jul 2008
    sumter,south carolina
    Did a coolant flush on my 05 n/a this morning. I hear a hissing noise in the process. Looking around I notice the noise is coming from number 2 injector. I can press down on the injector and it goes away. So I spit a little bit on it to see if air is coming out or sucking in. Well the spit immediaytely sucked into the cylinder. No gas coming out injector. is goin on?
    02 GTP with mods 05 GP for DD
  2. #2 Re: injector issue
    GTX Level Member cerick08GP's Avatar
    You need a new injector O-ring, I think you can buy a set of 6 for like $4.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: injector issue
    Jul 2008
    I kinda figured that. But sucking in air? I've had o rings go out before and they always leak fuel.
  4. #4 Re: injector issue
    Hagerstown,Md
    N/a injectors are in the Intake manifold, Hence the vac leak
  5. #5 Re: injector issue
    Jul 2008
    Ok that makes sense... I didn't even notice that. Was more focused on the injector itself. Is there a part number for the o rings that u know of?
  6. #6 Re: injector issue
    2008GP
    2002GP||sold
  7. #7 Re: injector issue
    If the o ring was bad on top it would leak gas on the bottom it will create a vacuum leak.
  1. Injector Orings
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2011, 04:51 PM
  2. miss on #3 bad injector?
    By 2003 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 10:29 PM
  3. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
  4. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  5. injector scaler
    By impalamike3800 in forum PCM Tuning
    Last Post: 06-09-2009, 03:22 PM
