Thread: L67 vacuum routing HELP!
Results 1 to 16 of 16
  1. #1 Re: L67 vacuum routing HELP!
    with a 97 blower on it.
  2. #2 Re: L67 vacuum routing HELP!
    Houston
    Nevermind...I see what yall are talkin about. Mine goes from the solenoid to the FPS as well. So just skip the manifold vacuum source #9
  3. #3 Re: L67 vacuum routing HELP!
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I dont have any evap stuff, i had it deleted so i run a T out of the lim to the map sensor and fpr then another T from th fpr to the bbv sulenoid throught the sulenoid to the bbv valve out of the bbv tho the tree on the sc. the other two ports go to the break booster and the ac controls and i block the port on the throttle body is this right? if so I got it and thank you all very much for the help
  4. #4 Re: L67 vacuum routing HELP!
    Houston
    I think you've got it.
  5. #5 Re: L67 vacuum routing HELP!
    GT Level Member Tea Time's Avatar
    New Brunswick
    if u deleted ur evap equipment then just cap off the line from the throttle body but everything else sounds right
    Check out the second post down on this link posted by the other nick....this is accurate for 98 - 03
    http://www.grandprixforums.net/2000-...nes-20389.html
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  1. sc vacuum tree.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-24-2011, 02:15 PM
  2. 2008 Grand prix 3800 belt routing
    By polishdog in forum General Tech Discussion
    Last Post: 12-28-2010, 12:05 AM
  3. looking for a vacuum line routing guide
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 12:02 PM
  4. Looking for info on 08 gxp amp power wire routing
    By chaverluk in forum Introductions/Noob Questions
    Last Post: 04-09-2010, 10:38 AM
  5. vacuum
    Last Post: 10-05-2009, 09:09 PM
