Thread: Shift lock solenoid wiring diagram/schematic
Results 1 to 15 of 15
  1. #1 Shift lock solenoid wiring diagram/schematic
    GT Level Member 40th GP's Avatar
    Utah
    So the dreaded 'won't come out of park' finally happened. Does anyone have a wiring diagram/schematic for the park lock solenoid? I want to put some power to it and confirm it is the solenoid. The ignition switch works just fine--key always comes out (after putting it back in park), it doesn't lock up, and everything else seems to work fine. When I push the shifter button I do hear a clicking in the steering column, so I think that solenoid is working, but I have to push the shift lock override button on the console to get out of park. It is getting annoying, and I actually just zip tied the override button so I can shift without pressing the button every time, but I want to get it fixed. Anyone have a pinout or know which wire I need to put power on to test the solenoid? I am also losing power when I press the brake pedal (as it should), so that switch is working. The BTSI fuse is also good and making contact.
    Also, anyone have any luck finding just the solenoid? The st(d)ealer wants to sell the whole shifter assembly for about $300.
  2. #2 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    Anyone have a diagram or know which wire is power to the solenoid? I really want to confirm that it is the solenoid and be done with it this weekend.
    Also, anyone know where to find just the solenoid, or am I looking at a junkyard or replacing the whole shifter assembly like the dealer says?
  3. #3 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    Nobody? I know others have had this problem. Does anyone have a schematic or able to let me know what wire needs power to test the solenoid? Anyone know of a fix for this other than replacing the shifter assembly?
  4. #4 Re: Shift lock solenoid wiring diagram/schematic
    Waukesha, WI
    i had the problem too, my solution pop the councel out and ziptie the shift lock button down
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Shift lock solenoid wiring diagram/schematic
    MI
    Solenoid should be bipolar, meaning you can apply voltage in either direction. Just ground one end and apply voltage to the other, if you are worried about the damaging it put a resistor inline to limit current.
  6. #6 Re: Shift lock solenoid wiring diagram/schematic
    MI
    The BTSI solenoid can be replaced if that ends up being the problem, it's up toward the front of the center console on most GM vehicles. On the cars that I've seen it's mounted on an L bracket only attached by 2 bolts.
  7. #7 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    I only see the solenoid that is right under the shifter itself. Is that the same one? Do you happen to know a part number or how to find it separately? The dealers I have called all told me you need to replace the shifter assembly, but the people I talked with sounded like morons.
  8. #8 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    Quote Originally Posted by GeeXPee View Post
    The wire harness/connector has 5 pins/wires going to it, so I don't know which goes to which end. If there were just 2 wires I would figure out which with a test light or try putting power to one, but since there are 5 wires I don't know what else they go to. If they are going to other solenoids and such I don't want to blow something putting power on the wrong terminal. Nobody has a diagram or knows which wire is the power feed?
  9. #9 Re: Shift lock solenoid wiring diagram/schematic
    MI
    Can you physically see the solenoid wires for the BTSI? If so there should only be 2 wires attached, could be wrong I guess not entirely familiar with all BTSI's. If you have access to the wires feeding the BTSI (not just the connector) you could put a small knick in the coating to get to the wire, then do a continuity test back to the connector. Once you figure out which pin it is you can test it from that point. I could probably help you out more if I could see what you are looking at.
    I'm guessing the BTSI solenoid was probably made by Delphi Steering, aka Nexteer. I don't have a part number...I know we use to send out new solenoids for warranty repairs that's what made me think you wouldn't need to replace the entire assembly. Sounds like I'm giving you false hope. Not sure how your mounts but it may be possible to replace it with a different solenoid giving the voltage and push/pull orientation and arm size are similar.
  10. #10 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    The camera on my phone SUCKS so these are not great, but here is a picture. It looks like the solenoid (fuzzy black thing under the bracket) is riveted to the bracket that is part of the shifter assembly. If that is the case it would be easy enough to drill out the rivets and bolt in a replacement, but just don't know where to find the replacement. I put red arrows pointing to the rivets, the solenoid, and the connector with 5 pins on it.
    Also don't know for sure that it is the solenoid that is bad since I don't know where to put power to test it. It has a 5-wire connector going to it.
    NEVER MIND...I STILL CAN'T GET THEM TO UPLOAD/ATTACH TO THE POST. I have tried before and for some reason it always says upload failed. I don't think I have even been able to upload pictures to this forum. I even tried zipping them and it won't take that. Anyway, I have some pictures sitting here but you can't see them. Scratch this post.
  11. #11 Re: Shift lock solenoid wiring diagram/schematic
    MI
    Ok...there may be a little bit of irony here. Do you work at Hill? I've seen a purple 40th anniversary around the 1279 area. I work at the F-22 SSO. Just realized that your banner said Utah didnt really connect the dots. If you want a hand and have a DMM I could take a look at it.
    Also just realized it but by hitting the brake it should change the state of the solenoid, i.e. you should be able to see the solenoid arm retract if it's working properly. If it's not it wouldn't retract, you can also find the power wire this way as well. The voltage in the power line is probably not there when the brake isn't pressed down depending on if it's active high or active low, so if you hit the brake and you see voltage on one of the wires (or if the voltages drops off) and the solenoid arm doesn't retract then it would be the solenoid. You would have to hash into the wires a bit but it would be easy to do.
  12. #12 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    That is not me, but I thought I saw another one rolling around here too. Did it have gold wheels? I thought I saw it up in Ogden once too (unless there are 2 more rolling around here), and have tried finding them with no luck.
    The actuator is not retracting--the solenoid is not doing anything. I do know which wire your talking about because I see the power switching with the brake pedal (I think pressing the brake stopped power going to that wire, but it could have been the other way around). Anyway, I do have a DMM and would like to get this figured out. PM me your info (or I can PM you) and we should get together some time.
  13. #13 Re: Shift lock solenoid wiring diagram/schematic
    MI
    Ah roger that, thought that may have been you. Sounds like you found the issue though, I can't see it being anything else. The voltage is probably dropping off on the line when you hit the brake, which it should. If I remember correctly it's always applied to lock the solenoid arm out, the brake cuts power and it retracts. So it sounds like the circuitry is working just fine, if there were any issues with the wiring the solenoid would retract since power wouldn't make it there and the car would shift out of park regardless of the brake pedal position. I'll send you a PM still though.
  14. #14 Re: Shift lock solenoid wiring diagram/schematic
    Minnesota
    If you guys do get this figured it out it would be greatly apreciated
    I have a hairtie around my shifter for a headphone cord through it that I poke the shift lock release everytime haha
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  15. #15 Re: Shift lock solenoid wiring diagram/schematic
    Utah
    I have not found a way to replace just the solenoid, and I am not going to spring $300+ at the stealership for a new shifter assembly, so for now I zip-tied the arm down so it will shift without having to release it every time.
  1. wiring schematic needed
    By copperpacecar in forum General Tech Discussion
    Last Post: 02-14-2011, 04:18 PM
  2. Shift lock solenoid
    By richard58 in forum General Tech Discussion
    Last Post: 11-17-2009, 04:45 AM
  3. wiring schematic for 3rd brake light
    By fst in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 04:24 PM
  4. Headlight Wiring Schematic?
    By singularity in forum General Tech Discussion
    Last Post: 09-04-2009, 01:36 PM
  5. Anti lock brake system electrical schematic?
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2009, 03:00 PM
