Thread: Someone please have an answer!!
Results 1 to 8 of 8
  1. #1 Someone please have an answer!!
    New York
    NEED HELP!! ITS WINTER AND My 97 Grand Prix sunroof tracks are offset. My driver side track is in the closed position, and the passenger side track is in a half open position. When the problem happened I was closing the roof and heard a hard clicking. It stopped working from that moment on. The tracks werent offset as much as they are now before I took the glass off. When I removed the glass, the passenger side track sprung back about 6 inches. The motor works, but the tracks only move about a half inch forward and backwards. Its cable operated and my guess is that one side jumped the track or a gear or something. Anybody help?
  2. #2 Re: Someone please have an answer!!
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Not an expert for this but common sense dictates:
    Try to shoot some pics. The sunroof will reverse direction if it encounters excessive resistance. That could be caused by grime buildup or lack of lubrication. Best to just clean the rails/sliding mechanism and lubricate, and do a visual inspection. Let GPF know what you find....
  3. #3 Re: Someone please have an answer!!
    New York
    could not locate the pics. However i did inspection for crud and grime in tracks. I see that its on some type on cable system when i took the glass off which i cant get back on due to the set back on passenger side arm of track. almost seemed like the cable skipped and is now out of whack.
  4. #4 Re: Someone please have an answer!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I dont have an answer But FYI its not winter its spring lol
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Someone please have an answer!!
    New York
    technically yes but 29 degrees SCREAMS WINTER TO ME
  6. #6 Re: Someone please have an answer!!
    I feel better about the 29 you are sending me than the 10 degrees you sent me last month.
    Sounds like sourcing a new roof track setup from a yard is in order.
  7. #7 Re: Someone please have an answer!!
    New York
    Ok well I got it all figured out kind of but still does same thing after tried it. An info on how to grease the mechanisms above headliner and what type to use. Seems to just keep slipping. Don't want to keep using it and have it strip the gears that would cost some pretty money I imagine.
  8. #8 Re: Someone please have an answer!!
    Omaha, NE
    For the tracks, you can use any silicone based lubericant, I used the stuff for I think it was for spark plug boots, I don't remember exactly. I know it was a couple of those $1 or $2 packets though.
    That is what I used per the advise of a GM mechanic and the autozone employees....
  1. Definitive answer...
    By ptnothere in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 12:13 AM
  2. need a quick answer will these fit??
    By tjsmithey in forum Tires & Wheels
    Last Post: 02-14-2010, 09:09 PM
  3. Can You Answer This
    By BillDee22 in forum General Tech Discussion
    Last Post: 09-04-2009, 03:37 PM
  4. i need a 4 sure answer!
    By boosting98 in forum Off Topic Discussion
    Last Post: 05-15-2009, 10:29 PM
  5. How Long for Ed to Answer
    By 02BlueGT in forum Off Topic Discussion
    Last Post: 01-30-2008, 09:16 PM
