Thread: PCM question
Results 1 to 5 of 5
  1. #1 PCM question
    SE Level Member djs4021's Avatar
    Youngstown, Oho
    I have an 01 GTP. What is involved in making the car run correctly if i replace the computer with another PCM from another 01 gtp(stock tune)? What if it isn't from an 01? Do i have to have a case learn done?
    01 Grand Prix GTP 8.8 MSD wires, K&N FIPK, ZZP Ceramic coated PLOG, ZZP 3'' Off-Road DP, Res Del, Borla Pro XS mufflers, Progress front sway, GMPP rear sway
    02 Bonneville SE with ZZP SSM90 kit. R.I.P
  2. #2 Re: PCM question
    plug and play pretty much, 98-02 pcm's are the same. 97 and 03 are different
  3. #3 Re: PCM question
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I always suggest a case learn when swapping between PCM modules. But other than that, its plug and play.
    For all your 3800 needs:
  4. #4 Re: PCM question
    Youngstown, Oho
    thanks for the feedback guys. Any idea how much the stealership wants to do this? What happens if I don't do a case learn?
  5. #5 Re: PCM question
    find some one with a aeroforce gauge or a tuner in your area, they can do it for you and hopefully not charge you. Thats your best bet.
    dont take it to a dealership.
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
