Thread: Worklog: On the 01 GTP *Update 3-27-11*
Results 1 to 4 of 4
  1. #1 Worklog: On the 01 GTP *Update 3-27-11*
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    This is the way i bought it 2300bucks!
    Came with
    -Short stack IC
    -ZZP ported GEN3
    -Stage 1 ZZP TB
    -PLOG, ported rear, 3inch DP
    -SLP loudmouth exhaust
    -XP cam
    -Double roller timing chain
    -KYB struts w/ B&G springs
    -F1 hood
    Added a genV w/ 65# injectors and e85
    Finished in 1week after owning it to just drive it some.
    After 2 scans and a little bit of tuning input shaft snapped on the trans!
    Got new trans in now with 7/8" chain w/ 3.29 grs with harden input shaft
    Picked up some decent 17inch rims
    Got bored and painted the GenV.
    And my purdy 78mm Billet TB to add to the genV
    Headers=TOG extremes!
    Some high temp ceramic coating
    genV m90 getting changed to m112 hybrid!
    It will look similar to this.
    Im working with a prototype engineer fab'n up the plate for me.
    GenV ic installed but ran into problems with VAC leaks by the IC and by the TB.
    Ran into a problem with the s/c belt hitting the back of the Coil paks. Nothing a few washers cant fix.
  2. #2 Re: Worklog: On the 01 GTP *Update 3-27-11*
    Dec 2008
    Sioux Falls,SD
    Bump for an update on the project
    Just your normal 730whp 4dr family car.
  3. #3 Re: Worklog: On the 01 GTP *Update 3-27-11*
    Jersey
    video of hybrid blower whine
    16' wrx sti- stock
  4. #4 Re: Worklog: On the 01 GTP *Update 3-27-11*
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by 99prixgt View Post
    When it gets finished trust me there will be videos and dyno #'s and track #'s
