Thread: info about headlight switch operation...
Results 1 to 14 of 14
  1. #1 info about headlight switch operation...
    hi im new to the grand prix area and was looking for some input if possible. i have a 02 gtp 40th edition and the headlights stay on no matter what position i put the switch to. i dont think that its correct but just wanted to ask others that have had there vehicles for awhile. i put the switch to park only and they stay on. any help would be great thanks.
  2. #2 Re: info about headlight switch operation...
    Saraland Alabama
    you have daytime running lights that stay on a bit dimmer than the headlights, and no taillamps, they are like that so others notice you
  3. #3 Re: info about headlight switch operation...
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Its really a nice feature. Or at least I thought it was until I went to the drive in... I couldnt turn of my lights until i turned the car off >:|
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  4. #4 Re: info about headlight switch operation...
    Saraland Alabama
    parking brake shuts them off
  5. #5 Re: info about headlight switch operation...
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    If you turn the dial VERY SLOW you'll find a spot between settings where the headlights turn off. I used it every day going through the gate on base.
  6. #6 Re: info about headlight switch operation...
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    I've heard that can burn out your switch, so I wouldn't recommend it for long periods of time (I'm sure going through the gate is fine).
    For anyone who wants to take complete control of their headlights:
    You can disable the DRL's buy unplugging the DRL module. On your driver's side, there will be a little panel on the side of the dash (only visible with the door open). Pry it up, and you'll see a connector plugged into a black module with a big heat sink, this is the DRL diode. Unplug this connector, and DRL's will go away permanently. (Note: DRL's are required in Canada, so if you live in the great white north I wouldn't do this.)
    Besides DRLs, your car also has twilight sentinel (automatic headlights), which will turn the lights on to full brightness when it gets dark out. These can be disabled by installing a resistor in place of the light sensor. The sensor is located under a little panel in the top center of the dash. The panel has two holes, one for the blinking red security LED and one for the light sensor. Pry up this panel, then unplug the sensor and slide a 4.7kOhm resistor in its place (the connector is tight enough to hold it there, or you can use some electrical tape to make sure it doesn't vibrate loose). Your car will now think it's daylight all the time and auto headlights will never come on.
    If you don't want do disable these features permanently, you can still disable them at the drive-in. Just park, set the parking brake, turn off your engine, then start the car. If the car is started with the parking brake set, both of these features will be disabled until the parking brake is released.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  7. #7 Re: info about headlight switch operation...
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by Warhellride View Post
    Great write-up!
    It's not like ya "gotta ROLL" at "lights out" anyway really, is it?
    Parking break ON!
  8. #8 Re: info about headlight switch operation...
    Highland Heights, KY
    I unplugged my DRL heat sink. I think it was it. Its black and has silverish cooling fins. Well they didnt go off i turned the key on and they were still on. whats that mean
  9. #9 Re: info about headlight switch operation...
    Apr 2008
    Chillin at the Beach , VA
    You can also just pull your DRL fuse. This will eliminate your DRL's and your automatic headlights.
  10. #10 Re: info about headlight switch operation...
    I found that right after i sent the message. Im loving it now. prefer to run just marker lights. Thanks
  11. #11 Re: info about headlight switch operation...
    GT Level Member BackInBlack's Avatar
    Vermont
    On some model years, simply pulling the fuse pisses off the BCM. See my web site for disabling the DRLs and Twilight Sentinel feature.
    The GPs are long gone...
  12. #12 Re: info about headlight switch operation...
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hi guys, im new to the forum so im not sure what you guys consider worse, bringing a thread back from the dead or creating a new thread on a topic that has been discussed numerous times
    anyways, i found this thread through a search and have a couple questions. first of all, where exactly is this drl diode? how exactly do i get to it?? second, in regards to posts 8 and 10, what years would be affected negatively by doing just this??
    also, i read the write up on backinblacks site regarding the lights, if you dont want these features at all, instead of installing switches, you can just cut the wires, right? and that wont cause any side effects?
  13. #13 Re: info about headlight switch operation...
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Jakegday View Post
    That is all here:
    BACKINBLACK's Grand Prix electrical mods page...
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  14. #14 Re: info about headlight switch operation...
    Nov 2008
    Fremont Nebraska
    yes, that is the site i looked at, which triggered my final question in that post....
  1. bad window switch help (GTP)
    By IndeedSS in forum General Tech Discussion
    Last Post: 07-26-2009, 11:23 PM
  2. Need a thermal switch
    Last Post: 06-27-2008, 01:30 PM
  3. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
