Thread: conversion GT-->GTP
Results 1 to 14 of 14
  1. #1 Re: conversion GT-->GTP
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Quote Originally Posted by thunder71173 View Post
    I am in the process of doing this conversion right now and since tou have the wiring harness go ahead and change it. If you plan on using your gt transmission you dont need the axle shaft but you will have to send your gtp pcm in to be tuned for the 3.29 gears. If you need any help with this just shoot me a pm and I will give you my number.
    Quote Originally Posted by That Canadian Guy View Post
    ideally you'd keep the GT transmission and drop the L67 in.
    3.29's make boost more fun.
    2 bad i dont have the time to get someone to tune it. its my dd so cant waste to much time
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #2 Re: conversion GT-->GTP
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    YOU CAN SEND IT TO JOHN AT INTENSE AND HE CAN TURN IT AROUND IN A COUPLE DAYS AND DELET ALL THE UNNECESARY CRAP LIKE THE EGR, EVAP AND REAR 02 SO YOU CAN RUN A CATLESS 3" DOWN PIPE. hE TURNED MINE AROUND IN LESS THAN A WEEK.
  1. conversion?
    By 02gtp40 in forum Visual/Body Modifications
    Last Post: 06-13-2010, 12:08 AM
  2. HID Conversion...which should I get??
    By machinegunsquid in forum Visual/Body Modifications
    Last Post: 05-09-2010, 05:10 PM
  3. HID conversion kit?
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-03-2010, 05:19 PM
  4. HID conversion kit
    By Haulero in forum General Tech Discussion
    Last Post: 03-29-2010, 09:03 PM
  5. gt conversion to s/c
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 10:52 PM
