ok so my car recently died on me and i got it towed to my house.....got it to start the other day and is throwing p0102(maf low freq)..... my afrs are in the 10-12s while idling and mt ltfts are at +26 sometime +3 (ive never seen these numbers before haha) car is running richer than dog shyt i can smell it and exhaust is moist.....if i try to drive it, it chugs and has a hard time staying running....today i have tried the following got a new lq4 and tried 2 diff ones and still same code checked for continuity on maf i only had continuity on pink n black and the resistance changed with key on and off i tested that.....new fuel pressure regulator went in changed upper o2 sensor.....changed fuel filter.....i have no idea wtf is going on unless my pcm is going wack.....i was merging onto the highway and got on it and shortly after that is when the car died the first time....car was running fine up until then....lost can anyone help me? map sensor is also good and car has no vac leaks
