Thread: my car sucks.....insight please.....
Results 1 to 5 of 5
  1. #1 my car sucks.....insight please.....
    Joliet, IL
    ok so my car recently died on me and i got it towed to my house.....got it to start the other day and is throwing p0102(maf low freq)..... my afrs are in the 10-12s while idling and mt ltfts are at +26 sometime +3 (ive never seen these numbers before haha) car is running richer than dog shyt i can smell it and exhaust is moist.....if i try to drive it, it chugs and has a hard time staying running....today i have tried the following got a new lq4 and tried 2 diff ones and still same code checked for continuity on maf i only had continuity on pink n black and the resistance changed with key on and off i tested that.....new fuel pressure regulator went in changed upper o2 sensor.....changed fuel filter.....i have no idea wtf is going on unless my pcm is going wack.....i was merging onto the highway and got on it and shortly after that is when the car died the first time....car was running fine up until then....lost can anyone help me? map sensor is also good and car has no vac leaks
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: my car sucks.....insight please.....
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Hmm, what PCM are you running?
    What do plugs look like?
    For all your 3800 needs:
  3. #3 Re: my car sucks.....insight please.....
    Joliet, IL
    havent checked plugs.....car idles smooth just cant handle load...
    00 Silvermist GTP
  4. #4 Re: my car sucks.....insight please.....
    stop running so rich.
    On a more serious note: have any scan logs?
  5. #5 Re: my car sucks.....insight please.....
    Joliet, IL
    nope tuner may stop by to scan today tho
    00 Silvermist GTP
  1. more insight needed
    By Bluemagic in forum General Tech Discussion
    Last Post: 12-23-2010, 04:11 PM
  2. Need Help/Insight - L67 stalling/running rough
    By RebelGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 02:12 AM
  3. this sucks
    By ammojunkie in forum General Tech Discussion
    Last Post: 12-30-2009, 05:39 PM
  4. wow this sucks
    By Will5600 in forum General Tech Discussion
    Last Post: 11-23-2009, 07:23 PM
  5. Some insight needed...I think I know what my problem is
    By Zef_66 in forum General Tech Discussion
    Last Post: 05-16-2008, 03:46 PM
