Thread: Sloshing Sound
Results 1 to 7 of 7
  1. #1 Sloshing Sound
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    When at a stop and starting to accelerate i hear a sloshing sound. Fivefingerdeathpunch said to drain the evap core/ heat box. How would i go about doing this?
    2002 GTP
  2. #2 Re: Sloshing Sound
    Omaha, NE
    Gas moving around the tank?
  3. #3 Re: Sloshing Sound
    Once again...
  4. #4 Re: Sloshing Sound
    Jul 2010
    Central Ny
    haha its not gasss or a fish tank lmao
    2002 GTP
  5. #5 Re: Sloshing Sound
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    It's very likely air in your coolant lines.
    Here Let me Google that for you
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  6. #6 Re: Sloshing Sound
    Chilliwack BC
    I had a similar issue in my 98 monte carlo (god bless her written off soul) i lifted the front end of the car with a hoist and bled the cooling system. no more sloshy. if you don't have access to a hoist, ramps or even raising the front end of the car with a jack should do the trick. Just don't forget to use the ebrake
  7. #7 Re: Sloshing Sound
    If the cooling system was low..it would kick on the low coolant light most of the time. There would be spotty heat and the temp gauge should reflect it being low.
    Buy goldfish. If you think you don't need them..check the spare tire area.
  1. Water sloshing in dashboard
    By JonnyQuest in forum General Tech Discussion
    Last Post: 01-04-2011, 08:25 AM
  2. new sound:)
    By beckys2000gt in forum General Tech Discussion
    Last Post: 07-03-2010, 06:19 PM
  3. This sound right?
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-28-2009, 12:29 AM
  4. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
  5. Water sloshing in the dashboard
    By Pontiacnutz in forum General Tech Discussion
    Last Post: 12-20-2008, 02:18 PM
