Thread: Wb o2
Results 1 to 20 of 20
  1. #1 Wb o2
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    I think I found the one... Unelss you guys tell me not to hahah
    heres what Im thingking Elite 10 Color Series Wideband Air Fuel Gauge
    Plus I have a 15% off code for them
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Wb o2
    Omaha, NE
    Innovate LC-1 should me much better and is 168 online.
  3. #3 Re: Wb o2
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    It uses a good sensor, I dont care for the Analog style read out myself. LC1 would be better, as well as a AEM IMO
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Wb o2
    Jul 2010
    Michigan
    I saw that but im half way hesitant mainly for the fact of not wanting just a digital read out which is all the LC1 does. another one the have does both analog and digital I have looked at this as well
    2005 GTP Grey
  5. #5 Re: Wb o2
    Hagerstown,Md
    Why would you want the analog style at all? just curious. Aem has the digital readout in the center and a rich/lean readout along the edge thats color cordinated
  6. #6 Re: Wb o2
    Donating Users Ibwrong's Avatar
    Oklahoma City
    X2. I wouldn't go with glow whatever if it came to a wideband...trust a company that knows what they are doing
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  7. #7 Re: Wb o2
    With an analog readout it would also probably be slower from lag...digital is where its at.
  8. #8 Re: Wb o2
    Jul 2010
    Michigan
    Only reason for an analog is its alot easier to just use as a reference if im just looking to make sure things seem right so im not staring at a number trying to work that out in my head.
    2005 GTP Grey
  9. #9 Re: Wb o2
    Omaha, NE
    The LC1 can go to a vaious number of gauges, I saw a list somewhere yesterday and it was large. You may want to check into that further if you want a good wideband with an analog readout.
  10. #10 Re: Wb o2
    Jul 2010
    Michigan
    Yes but then were talking 160$ LC1 plus a gauge. I dont mind the AEM which for about 160 its all inclusive. Thats a good possiblity
    2005 GTP Grey
  11. #11 Re: Wb o2
    Hagerstown,Md
    trust me its alot easier to look at the actual number then a sweeping needle.
  12. #12 Re: Wb o2
    Jersey
    aem all the way
    16' wrx sti- stock
  13. #13 Re: Wb o2
    analog gauges are digital, they are just as fast. however, they are harder to read unless you KNOW what each section means with just a glance.
  14. #14 Re: Wb o2
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    unless you KNOW where your a/f ratio is supposed to be, it is usless and looks cool. just informing here, but a narrowband 02 and af guage is designed to be read between a very tight set or parameters while the wideband 02 and af guage is designed to be used with a broader range of paramters. unless you've had the car tuned or going to have it dyno tuned and is going to be tuned outide the stock ratios. a wideband on a stock tune is usless cuz the pcm will be adjusting the af ratio within the stock pre-set parameters which is usually between 14.1 to 14.7
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  15. #15 Re: Wb o2
    Quote Originally Posted by taman86 View Post
    you do realize that we are talking about a digital (7 segment numbers) versus a analog (dial with a needle like most gauges) wideband gauge, right?
  16. #16 Re: Wb o2
    Jul 2010
    Michigan
    So ultimately if i decide to go with a gauge that has both I would have the best of both worlds. Does everyone agree :P
    2005 GTP Grey
  17. #17 Re: Wb o2
    Nov 2010
    south east AZ
    bio, yes i do realize i was just pointing something out to be concidered.
    01 T/A WS6-SOLD
  18. #18 Re: Wb o2
    Nov 2010
    south east AZ
    i was not talking about specific guages but generally talking about a/f tunes
    01 T/A WS6-SOLD
  19. #19 Re: Wb o2
    Jan 1970
    Maquoketa, Iowa
    I see that if you go with this guage you will want to get the output signal wire for $10. Then you can hook it up to the scanner to get your readout in numbers.
  20. #20 Re: Wb o2
    Jan 1970
    Maquoketa, Iowa
    I saw you have an aeroforce, You could aslo get this and still have the output -
    Aeroforce Technology Inc | Products - Sensors
