Thread: hooking up a boost gauge
Results 1 to 14 of 14
  1. #1 hooking up a boost gauge
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Alright. So I got my boost gauge ready to go (wiring wont be a problem minus finding a good ground) and I need to know the best place to hook up the T. I have an area right on top of the SC that looks like a 3 way connection and has vaccuum lines coming out of two of the ports. However, the middle port is just capped. Can I just plug my line into this extra port??
    Also, it is an 05 where is the easiest place to get it into the bay and to the gauge? Am I going to have to drill a hole in the firewall to accomplish this easily?
    Thanks for the help guys
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: hooking up a boost gauge
    Going to the top of the SC is prerotors and all you'll get is vacuum. Best place to hook up is around back by the map sensor. This way it's out of the way and not ugly.
  3. #3 Re: hooking up a boost gauge
    Jul 2010
    Michigan
    Alright thats what I was questioning thanks Bill! and advice on the firewall issue?? or how to get the line into the cockpit
    2005 GTP Grey
  4. #4 Re: hooking up a boost gauge
    You can run inside is a few different places like the throttle cable or trans shift cable areas, down by the power steering is the boot for most of the wiring into the cabin. I think there might be one on the driverside as well.
    Or you could drill
  5. #5 Re: hooking up a boost gauge
    Jul 2010
    Michigan
    Alright I will have to get under her when I have another chance and take a look any dangers to drilling?
    2005 GTP Grey
  6. #6 Re: hooking up a boost gauge
    GT Level Member starscream5000's Avatar
    Kentucky
    Mine's an '05 as well, I ran the vacuum line against the firewall all the way to the driver's side strut tower. I then lifted up the seal strip for the hood where it meets the fender and there's a small gap there that a vacuum line will fit through. I took off the plastic cover for the windsheild wiper and ran it through there and down to the door and into the cabin. Lazy man's way I know, but It's working just fine for me and I've got it zipped tied out of everything's way to keep it from binding somehting up.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  7. #7 Re: hooking up a boost gauge
    Jul 2010
    Michigan
    It doesnt kink anywhere along the way?? We were looking at doing it and were unsure if we could manage it without kinking or restricing the line. Trust me while we were busting our brains that came to mind. Do you happen to have a picture of how it looks in the engine bay where its running?
    2005 GTP Grey
  8. #8 Re: hooking up a boost gauge
    HUDSON
    Did you know you do not even need to open the hood to install a boost gauge? There is a vacuum line inside the car interior that can be used.
    It is the hose that goes to the vacuum resivour for the HVAC system, and you can "t" into it jsut before the check valve that goes into the vacuum resivour.
    It is located on the passanger side footweel.
  9. #9 Re: hooking up a boost gauge
    Houston
    Quote Originally Posted by QUICKSILVER462 View Post
    That would be the same as 't'ing in at the top circle in the pic
  10. #10 Re: hooking up a boost gauge
    HUDSON
    I don;t know why I had the boost gauge confused with a vacuum gauge.
    So, If you want to hook up a vacuum gauge......
  11. #11 Re: hooking up a boost gauge
    SE Level Member genvgtp's Avatar
    Apr 2011
    griffith indiana
    I need help with a digital auto meter boost gauge i have a 2005 grand prix and i dont know what to wire it to
  12. #12 Re: hooking up a boost gauge
    GT Level Member grandprix5's Avatar
    brownsville
    where do you connect the boost gauge when you have 2005 grand prix non supercharged ??? i have a turbo on it but do i connect the boost gauge to the break booster ??
  13. #13 Re: hooking up a boost gauge
    i would connect it somewhere on the cold piping near the throttle body. just put a nipple in and run with it.
  14. #14 Re: hooking up a boost gauge
    brownsville
    oh okdo they sell any type of adapters ?
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
