Thread: BCM reprogramming.
Results 1 to 3 of 3
Slick2500 BCM reprogramming. 03-22-2011, 01:42 AM
Ibwrong Re: BCM reprogramming. 03-22-2011, 04:43 AM
Slick2500 Re: BCM reprogramming. 03-23-2011, 11:43 PM
  1. #1 BCM reprogramming.
    I can't seem to find out how to redo the BCM so that when you shift the car into park the doors unlock, the manual for my 01 GT had the instructions for doing this, but my GTP's manual does not. Could someone post the instructions here for me?
  2. #2 Re: BCM reprogramming.
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I thought this was an option after a certain year, possibly '00... If your car supports it try this:
    Its relatively easy.
    Turn the ignition to Off (the spot where you'd pull your key out)
    Pull the Mall PGM fuse from the box.
    Turn the ignition to Accessory (1 click counterclockwise from Off, or to the left)
    Push the Unlock button. You'll hear a number of chimes corresponding to the setting your car is in, the factory default is 3. Push the Unlock button once more to move the setting to 4 and you'll be set.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: BCM reprogramming.
    Ok sweet thanks, yeah the manual for my 01 GT had how to reprogram everything in it, I tried googleing that but didn't find what I was looking for.
  1. Key FOB Coding-Reprogramming
    By CVM116 in forum General Tech Discussion
    Last Post: 10-19-2009, 07:07 PM
  2. Pcm reprogramming
    By Joe Cabras in forum PCM Tuning
    Last Post: 09-14-2009, 03:33 PM
