Thread: After bearing changed ABS/TCS Going crazy
Results 1 to 2 of 2
  1. #1 After bearing changed ABS/TCS Going crazy
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    After getting my front driver side wheel bearing changed my TCS button has been working again. Problem is now whether i turn it on or off, when i first start drivingit half engages for 1/2 a sec. Then a couple stops sometimes it does a longer engage that scares me because it makes the car not stop like i need it tooo. It was completely dry outside when all this happened so i have no iteas whats going on.
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: After bearing changed ABS/TCS Going crazy
    Double check the wiring, connectors and the clip to the backign plate. Any/all could be suspect.
  1. Things sure have changed
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 10-12-2010, 02:40 AM
  2. for those of you that changed. upgraded rad
    By kuntzie in forum General Tech Discussion
    Last Post: 07-04-2010, 09:24 PM
  3. Changed It Up A Bit (New Pics)
    By Dboy23 in forum Off Topic Discussion
    Last Post: 05-12-2010, 03:33 PM
  4. So alot has changed.....
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 03-23-2010, 05:27 PM
