Thread: Air Bag Light code:B1015. Any tips?
Results 1 to 17 of 17
  1. #1 Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    My airbag light started coming on about a month ago. At first, it was only on about one out of every five times I started the car, but now it is on almost everytime. I had it scanned, and they said it was a code B1015 which means Passenger side deployment loop resistance high.
    Is there anything I can do to fix this myself before I take it to a dealer. I really don't have the money to pay high dealer costs.
  2. #2 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    Bump. Anyone?
  3. #3 Re: Air Bag Light code:B1015. Any tips?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    what year of car do you have?
    i searched google and saw this TSB...
    Air Bag Warning Light On, Set Dtc B1015 (replace Jumper #83-90-10) - MyMonte
  4. #4 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    Sorry I forgot to put that, it's a 98 GP SE.
    Well, the link you posted talks about high resistance, and that is what the code said, so this should be my problem, right?
    I'll go outside and check my Vin # now.
  5. #5 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    if you do have a 98, then yeah that TSB does cover your car. though depending on the car's service history, it may have been performed already. if not, that's a good start.
  6. #6 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    I checked the Vin, and my car was built prior to WF293247.
    I guess I'll probably start here then. From my understanding of what it says, I remove the airbag, replace the wire, then reinsert the airbag. This seems pretty straightforward to do, if someone could explain how to remove the airbag.
  7. #7 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    from another page i saw in my search, the pigtail (pn 16758256) actually gets plugged inline with the current harness (unplug old harness from airbag, plug new harness to airbag, plug old harnes to new harness.
    i'll look and see what i can find on removing the airbag, but you have to disconnect LOTS of things to be messing with the airbags.
  8. #8 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    I was looking, and I found a guy with the same problem on another forum, but then when he asked how to get into the airbag, people stopped answering.
    Thanks so much for your help.
  9. #9 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    You take full responsibility for messing with your airbag-- i dont. this is just what i have read.
    this is what the service manual says for disable airbag:
    REMOVE AND DISCONNECT
    • Turn the steering wheel to the straight ahead position.
    • Remove the key from the ignition switch.
    1. AIR BAG Fuse (Buick) or SIR Fuse (Pontiac) from the I/P fuse block.
    2. I/P insulator (left side).
    3. Connector Position Assurance (CPA) and the driver yellow 2-way connector located at the base of the steering column.
    4. Connector Position Assurance (CPA) and the passenger yellow 2-way connector located near the base of the steering column.
    IMPORTANT
    With the AIR BAG Fuse (Buick) or SIR Fuse (Pontiac) removed and the ignition switch in the RUN position, the AIR BAG warning lamp illuminates. This is normal operation and does not indicate a SIR system malfunction.
    enable airbag:
    INSTALL OR CONNECT
    1. Passenger yellow 2-way connector and the CPA located near the base of the steering column.
    2. Driver yellow 2-way connector and the CPA located at the base of the steering column.
    3. I/P insulator (left side).
    4. AIR BAG Fuse (Buick) or SIR Fuse (Pontiac) to the I/P fuse block.
      • Staying well away from both air bags, turn the ignition switch to the RUN position. Verify that the AIR BAG warning lamp flashes seven times and then stays off. If the AIR BAG warning lamp does not operate as described, perform the SIR DIAGNOSTIC SYSTEM CHECK
  10. #10 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    Thanks for that information, but do you also know how to actually get to the harness where I am supposed to insert the pigtail?
  11. #11 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    Quote Originally Posted by spenc938 View Post
    you may be able to get to the wire harness from under the dash, but if not, i think perhaps the dash cover has to come off? i cant tell from the service manual i have, it's not clear on the passenger side airbag, but it looks like the screws that hold it in place go in from the top.
    ---- i just did some quick ebay searching, thogh and at least from what i can tell, the original harness connected to the airbag module is a pigtail (wires permanently connected on one end) with what looks to be almost a 1ft pigtail... so you may not need to remove the airbag to install the the new add in harness, but not sure.
  12. #12 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    I'll have to go out in the car tomorrow and try to identify all the different things you have talked about. I would like to do it right now, but it is dark.
    I'll be back tomorrow with more questions. Thanks again for your help.
  13. #13 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    the airbag connectors and assocated wiring are all BRIGHT yellow... and the connector bodies themselves should be unique shaped as well.
  14. #14 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    That is good to know. Should help me in my search for connectors tomorrow.
    If anyone else has something to say, please, feel free.
  15. #15 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    I went out and looked, and couldn't find any of the things I was looking for. I took the glovebox out, and did see a single yellow wire, but I doubt that is it.
    And for the wires by the steering column, is there a cover that I have to remove?
    Edit: Maybe I'll buy a Haynes manual. Would this be able to help me in finding the wires?
  16. #16 Re: Air Bag Light code:B1015. Any tips?
    SW Chicago Suburbs
    the cover that they're talking about removing is the plastic panel directly below the steering column... which will also require removal of the "carpeted" cover that goes under the rest of the dash.. should come out pretty easily. as for the passenger side, the wire your looking for is indeed yellow, but it's likely got a few conductors inside that yellow jacket, so it wont be skinny. if you get your hands on the new harness, you'll be able to see what the connector looks like. the connector is also yellow.
  17. #17 Re: Air Bag Light code:B1015. Any tips?
    Feb 2008
    West Jordan, UT
    The special order part finally arrived today, but now the damn light isn't even on anymore. I'll just save it in case the light comes on again.
  1. 98 GP GT with a PO442 code and light on.
    By Fritcr in forum General Tech Discussion
    Last Post: 11-17-2011, 06:39 AM
  2. Exhaust Tips
    By SlowPurpleGTP in forum Visual/Body Modifications
    Last Post: 05-16-2008, 08:34 AM
  3. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
  4. Need tips
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 11:55 AM
