inj. e85 and enjoy no kr
i gotz no moniez lol
You could be trying to run as much as 20* timing in the car without knowing what was done to the pcm. These 100k+ cars are not as consistent anymore as they were back when most of the vendor tunes came out, maintenance, motors, different changes could all have a larger affect at the age they are at now. If you want a good tune, have someone tune it that knows these cars and has a wideband so you aren't throwing a hot dog down a hallway.
well i put that NOS octane booster in and it got rid of all my knock
you're sh!ttin me, that stuff actaully works?!
plz give me your recipe.....youre way better off home brewing your own race gas.
Here is the formulas again.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
For more info visit this link.
http://kcpmc.proboards.com/index.cgi...ay&thread=7467
so what you're saying in that formula is if you mix 30% of whatever formula mixed with premium equates to 'x' octane in a 16oz bottle. so once you mix that bottle of 'x' octane into say 14 gallons of gas that would probably just completely dillute it, would it not. you would literally need about 3 gallons of 'x' octane booster to boost the whole gas tank, or am i missing it all together.
Oooohhhhhh
Niice! I may just have to try this....Just hope I dont go kaboom lol![]()
In az its 91, lame
So where can these chems be had from
Gotcha
