Thread: Thermostat on 04+ question
Results 1 to 14 of 14
  1. #1 Thermostat on 04+ question
    SE Level Member Jackd90's Avatar
    Chicago
    Having just passed 60k miles, I've been doing some maintenance (coolant, tranny, brakepads, plugs, etc) and my next step is getting new spark plugs.
    I read the "safely modding.." thread and did some research on getting a cooler thermostat along with cooler plugs. I read that it isn't wise to change the thermostat to a cooler temp on newer cars.
    What do you think? Should i just leave the stock thermostat, and get stock temperature plugs?
    Open Cone Intake, 180° Tstat, Autolite 605 Coppers, Autolite 7mm wires (will upgrade soon), Muffler delete (headers soon)
  2. #2 Re: Thermostat on 04+ question
    stock car? stock plugs/wires/t-stat.
    less problems, more fuel economy.
  3. #3 Re: Thermostat on 04+ question
    Chicago
    Hmm... thanks, that's what I figured. I don't have any mods other than the open cone intake and pipes in place of the mufflers lol
  4. #4 Re: Thermostat on 04+ question
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    And if I remember correctly that you would have to do some tuning with your PCM for the thermostat to actually run beneficially.
  5. #5 Re: Thermostat on 04+ question
    Quote Originally Posted by csssaint12 View Post
    yup. the car still runs hotter because the radiator fan turn on temperatures arent set right.
  6. #6 Re: Thermostat on 04+ question
    It still wont be beneficial.
    unless you consider throwing gas away, beneficial
  7. #7 Re: Thermostat on 04+ question
    Pennsylvania
    Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock Stock
  8. #8 Re: Thermostat on 04+ question
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Yea all i have is a 3"DP homemade intake tuned pcm and 180 stat i had copperpacecar hook up hptuners to test for knock i had about 3* at WOT in high RPMs i put a 160 stat in(as per his suggestions) lost 2 miles per gallon but she is running like a champ due to not loosing timing
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  9. #9 Re: Thermostat on 04+ question
    Quote Originally Posted by klj5022 View Post
    nothing you just said makes sense.
  10. #10 Re: Thermostat on 04+ question
    Chicago
    Thanks everyone.
    Also, what spark plugs would you suggest (brand/material) ?
    EDIT: Nevermind, recommendations for spark plugs are given in the Safely Modding Your 3800 Powered Car!! thread
  11. #11 Re: Thermostat on 04+ question
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    the only reason you dont see knock is bacause from the factory, the knock sensors dont turn on untill ~175. so if your car never gets that warm or you havent lowered the knock sensor turn on point, your car is still knocking, you just dont see it.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  12. #12 Re: Thermostat on 04+ question
    Omaha, NE
    You can't run 160* tstat on an 04+, It'll throw codes.
  13. #13 Re: Thermostat on 04+ question
    get delcos
  14. #14 Re: Thermostat on 04+ question
    I thought it was 160.
    Must talk to will....
  1. First Post, Thermostat question
    By 04BlackGTP in forum Introductions/Noob Questions
    Last Post: 12-12-2010, 07:45 PM
  2. thermostat question
    By mcsddd in forum General Tech Discussion
    Last Post: 08-02-2010, 07:19 PM
  3. Thermostat question
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2010, 07:29 AM
  4. Thermostat question.
    By TCM05GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-15-2009, 10:43 PM
  5. Thermostat went out got a question
    By jasonball in forum General Tech Discussion
    Last Post: 02-08-2009, 01:33 AM
