Thread: no heat coming out of heater
Results 1 to 8 of 8
  1. #1 no heat coming out of heater
    PA
    Okay now here is my issue, I just replaced the water pump, thermostat, all hoses, serpentine belt and removed the coolant resevoir to completly clean it out. I don't seem to have any leaks, but now my heater doesn't get hot when the car comes up to temp.
    thanks in advance for any help,
    Jim
  2. #2 Re: no heat coming out of heater
    do you bleed the all the air out of the system?
    and maybe your heater core is clogged.
  3. #3 Re: no heat coming out of heater
    PA
    Fivefinger,
    How do I bleed out the lines? Thanks for the quick responce.
  4. #4 Re: no heat coming out of heater
    ontop of the thermostat housing in a nut/bleeder valve.
    Open that ( turn it 2 full turns, just enough to open it) and start the car and let it run up to operating temp. Watch the air and coolant come out (coolant will come out, but not a boat load).
    Let the car run and keep and eye on the air bubbles and wait for them to pretty much stop. It may take up to 10-15 min to get it all out so give it time.
  5. #5 Re: no heat coming out of heater
    PA
    Fivefinger thanks again for the help, I will try that 1st thing tomorrow. I will post back to let you know how I made out.
  6. #6 Re: no heat coming out of heater
    PA
    Fivefinger, did what you said & there was alot of air in the line. took about 20mins, got all the air out heater works fine, but now the low coolant light is on and coolant level is fine.
  7. #7 Re: no heat coming out of heater
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    are you basing the fact that it is full based on the overflow tank, or have you popped the rad cap and looked down into the rad to see if it is full. just cause the overflow is full does not mean that the radiator is full.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  8. #8 Re: no heat coming out of heater
    Jul 2008
    sumter,south carolina
    ^ what he said.
    02 GTP with mods 05 GP for DD
  1. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  2. Burning Coming From Heater
    By Sn00pa F1y in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 03:05 AM
  3. Did they see me coming?
    By collforone in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 01:45 AM
  4. heater problems/no heat
    By cartkid14 in forum General Tech Discussion
    Last Post: 12-23-2008, 06:11 AM
  5. heater problems/no heat
    Last Post: 12-22-2008, 11:22 PM
