Thread: Burning Coming From Heater
Results 1 to 4 of 4
  1. #1 Burning Coming From Heater
    Feb 2010
    Canada
    Hi, im new to the forums and overall new to the GTP scene. I own a 97 GTP
    When i start up the car, the inside of the car fills up with an oily smokey smell. It looks like the car is burning oil. I checked through the maintenance records that i recieved from the seller and it shows that he has had the front valve covers replaced due to a recall. The smoke is coming from the back of the engine. What could this be?
  2. #2 Re: Burning Coming From Heater
    in a house
    The rear rocker cover?
  3. #3 Re: Burning Coming From Heater
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    It's likely the rear valve cover. If it's smoking that bad I wouldn't run it or drive it at all. Probably needs the top end rebuilt with new gaskets too.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  4. #4 Re: Burning Coming From Heater
    in a house
    Quote Originally Posted by GTPcoupe View Post
    Lets not get to carried away here. Top end rebuilt with new gaskets?
    I think replacing the rear rocker gasket will solve your problem. Oil is leaking down onto the exhaust manifold and smoking. The intake for the blower motor is right their so naturally its going to pull some of that smell into the car. If you can do the work yourself its a cheap fix.
  1. Gas Burning QUICK!
    By ThePrixGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2009, 08:09 PM
  2. Burning oil, misfire #2
    By Blackbeauty01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2009, 03:43 PM
  3. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  4. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
  5. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
