Thread: 2 questions. brakes and fuel injector
Results 1 to 8 of 8
  1. #1 2 questions. brakes and fuel injector
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    alright guys, i need brakes. i wanna do the 12 inch upgrade. i should be able to get 12 inch rotors and use my stock calipers right? and what about the brake pads? do i use the same brake pads? does anyone know how i can get 12 inch rotors besides off of zzp?
    now fuel injector. i notice ppl put injectors that push more pounds. is that a big hp boost and does it hurt gas mileage? my fuel injector in cylinder 2 is so bad that its making my car run like crap really bad and i'm not sure what i wanna do. i dont wanna spend a lot of money. my car is stock besides a cold air. i'm sure running only one injector that pushes more pounds is bad right? `a stock injector is like 75 bucks and i'm broke and slightly cheap. if anyone could answer those questions that would be great. thanks guys
  2. #2 Re: 2 questions. brakes and fuel injector
    only point in new injectors is if you need more fuel.
    if you dont need it, its a waste.
    if you're stock, you have quite a bit of headroom with the stock injectors.
    you'll need the larger caliper brackets as well, yes stock pads work.
    Try zzperformance.com
    they have some stock injectors for pretty cheap compared to other aftermarket.
  3. #3 Re: 2 questions. brakes and fuel injector
    Nov 2010
    Illinois
    what would i need more fuel for?
    and bummer, i was hoping i could just get the 12 inch rotors and get away with that. i dont wanna have to buy new brackets too. would the stock calipers be able to bolt up to the new brackets?
  4. #4 Re: 2 questions. brakes and fuel injector
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    yes stock caliper bolt to new bracket stock pads work all you need is impala,monte carlo rotors and caliper braket thats it everything fit no custom work needed straight bolt in
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  5. #5 Re: 2 questions. brakes and fuel injector
    more fuel if your engine flows well enough to require it.
  6. #6 Re: 2 questions. brakes and fuel injector
  7. #7 Re: 2 questions. brakes and fuel injector
    Nov 2010
    Illinois
    wow you're right its 20 bucks thats not bad at all! thanks for all the help guys. i'll just stick with stock injectors.
  8. #8 Re: 2 questions. brakes and fuel injector
    If it were me...I'd be cruisin to the local junkyard. Injectors are $5 and caliper brackets...lol maybe $10 for the pair.
    Do your homework and find out what these parts come off. Why line a vendors pockets and pay shipping when these pieces can be had cheaper and quicker locally?
    I got F body brakes shipped from Florida with brackets etc for $60, then added rotors and pads of my choice.
  1. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
  2. fuel injector / pcm issues?
    By mastert429 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:43 AM
  3. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
  4. stock fuel injector rating?
    By elusive racing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 11:45 AM
  5. Fuel Injector O-ring ????
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2008, 05:16 PM
