Thread: Keyless Entry Woes
Results 1 to 5 of 5
  1. #1 Keyless Entry Woes
    Oklahoma
    We purchased our 2000 Grand Prix SE this past weekend. The previous owners had 2 key fobs that they gave us. However, after replacing the batteries and trying all the "tricks" I could find online to program the things, I finally took it to a dealer yesterday.
    The dealer hooked it up on the Tech 2 and said that the computer is not recognizing the keyless entry. They ran the vin and everything and the car does have a keyless entry system and even an alarm system, but it is just not recognizing that one is there.
    I had them check both remotes. One is a GM ceritified remote and the other they think must be an after-market remote. They both tested good and transmitting on their system. However, they could not get it to program. They said I could make an appointment and come in and they will try to find out the wiring issue. The cost would start at $65 and go up from there.
    I was wondering if any of you have had a similar problem or have an answer for me. One more thing to ad...Occasionally when I look at the radio, the numbers are rolling digital segments (not full numbers) and sort of flashing. Usually when I turn the car off, it corrects itself.
    any help?
  2. #2 Re: Keyless Entry Woes
    St. Louis
    Have you checked for any blown fuses? It sounds like the receiver in the car is dead.
  3. #3 Re: Keyless Entry Woes
    Oklahoma
    I checked the fuses. They are all good. Where would the receiver be that would be possibly bad located at....easy replacement? or not?
  4. #4 Re: Keyless Entry Woes
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    I had the same exact problem and did the same thing and went to the dealer. They said they think my BCM could be bad or it could be a wiring problem.
    -ljmonnin12
  5. #5 Re: Keyless Entry Woes
    Oklahoma
    Did you ever get it fixed? If so, how much did it cost?
    Did you have any another issues going on like the radio going crazy every once in a while?
  1. fix my keyless entry!
    By foursixer in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2011, 07:20 PM
  2. Keyless entry
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 09:14 AM
  3. 94 keyless entry
    By eeltam in forum General Tech Discussion
    Last Post: 01-05-2011, 05:49 PM
  4. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
  5. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
