Thread: electrical problems
Results 1 to 11 of 11
  1. #1 electrical problems
    Michigan
    I have a 04 grandprix gt 3. 8 I have had a major problem with water leaking into the passenger side floor and now my dash is goin crazy no cruse no gauges all dummy lights go on and off but what is really pissin me off is it goes in and out of over drive all the time. I only drive on the freeway to work can anybody help please. Love the site thanks.
  2. #2 Re: electrical problems
    Hi and welcome...
    If you post up yoru issues in the electrical/mechanical section it'll surely get much more exposure and responses.
    Meanwhile.. enjoy the site and hope to see the car fixed up soon.
  3. #3 Re: electrical problems
    Michigan
    Duh thanks man
  4. #4 dash out
    Michigan
    Major problem with my instrument panel not working on my 04 if I shut the car off the fuel pump kicks on that's it dead
  5. #5 Re: dash out
    St. Louis
    Have you checked all the fuses?
  6. #6 04 electrical problems
    Michigan
    I have a major problem with my 04 3800 gt water leaking in the passanger side .now no instrument panel at all and if I shut the car off and turn the key fuel pump kicks on but nothing else dead I NEED...
    Help bad. Turn the key and no dash lights just the relay clicking on pass side.
  7. #7 electrical
    Michigan
  8. #8 Re: 04 electrical problems
    Topeka, KS
    Read this to fix your water problem.
    http://www.grandprixforums.net/water...-fix-6961.html
    Also check your fuses in your glove box.
  9. #9 Re: electrical
    this will fix the water problem on the floor http://www.grandprixforums.net/water...-fix-6961.html
    and check your battery's connections first, clean them, reconnect, check battery voltage, or try to jump start it, one loud click could be the starter trying to turn, but dont have enough power to do so.
  10. #10 Re: electrical
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Is the water leaking from the front passenger door side? Because if so check your fuses because thats were 1/2 the fuses are.
  11. #11 Re: electrical problems
    Having four threads on the same topic means the people who will respond will not have the most complete version of the story. Thus make it MORE difficult to diagnose your problem.
    Please keep it all in this thread.
    Thank you.
  1. Electrical problems....
    By Max PowerX360 in forum General Tech Discussion
    Last Post: 04-02-2010, 11:50 AM
  2. few electrical problems
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2009, 09:49 AM
  3. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  4. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
  5. i think im having electrical problems...
    By 2000GTP in forum General Tech Discussion
    Last Post: 01-17-2009, 08:36 PM
