Thread: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
Results 1 to 19 of 19
  1. #1 Re: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
    GT Level Member GtpKo's Avatar
    Best place on Earth
    Just one note(ok a few): make sure you don't get the dielectric grease on the metal contact or it will corrode it again. Take sandpaper and clean up the prongs on the coil packs. If the wires have corroded contacts, just get new OEM ones.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  2. #2 Re: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
    SE Level Member 9ordohz's Avatar
    CA
    Quote Originally Posted by GtpKo View Post
    ok cool,
    but i went to freakin autozone.. all they had was the cheap ones (well for me they sound cheap.. DURALAST haha) & also the BOSCH
    or where can i get em? napa? & how much would it be?
    99Gtp*5% tint all around *Hids: 1ok headLights, 1ok Foggs *CUSTOM CAI *3"CATBACK *SLP HEADERS *Satin Blk torQue starz *7" Flip Screen *15" Sub *1800w kw amp *1200w 4ch. *SS Epicenter (: *&MORE TO COME ! *JUST STARTING OUT .....
  3. #3 Re: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
    Soooo WOTGTP stopped over with headers yesterday afternoon. If he arrived at 4pm... We ran into major issues for a header install. He drove home a little before 11pm. We actually worked on it about 4, maybe 5 hours.
  4. #4 Re: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
    CA
    damn u.u
    what kinda issues?
  5. #5 Re: Bad surprises w/ header install :( abs/tcs light.. Crappy mpg, misfires :(
    His car had been modded before and it's becoming clearer that it was even more modded than it is now. He found rockers, springs and a 3.8mps. The car probably had headers before, some bolts were super tight etc.
    One of the studs in the head broke when trying to remove the nut from it. That never happens, never. With him holding the mirror and light, I freehand drilled it with a right angle drill. Then a trip to Sears for an extractor. Got it out and breathed a sigh of relief. Later on with the piece in the vice to remove it from the extractor, the extractor broke. I smiled and thought...that's the best time it could have chosen to break.
    Oh..and somehow a SC plastic wire holder found it's way onto the motor, making his cool red wires look nice and neat.
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
