Thread: Problem with starting sometimes and hesitation with wot
Results 1 to 3 of 3
seanparker3 Problem with starting... 04-28-2011, 07:13 AM
Taz Magister Re: Problem with starting... 04-28-2011, 07:20 AM
seanparker3 Re: Problem with starting... 04-28-2011, 01:49 PM
  1. #1 Problem with starting sometimes and hesitation with wot
    mentor
    Ok, so about a month or two ago I couldnt start my car and we went through the possibility that my engine was seized. After a nightmare in the cold i found out the reason was that my ac compressor pulley seized so I replaced it with the elimination pulley. I also changed my plugs since I already had them pulled. the car was running great and the minor squealing from the s/c belt even stopped. Now I am having problems with the car starting again. Sometimes it wont turnover and just dies when i turn the key like another pulley is siezed. I also am having hesitation when punching it in higher gears. The boost guage comes on instantly when I hit the gas in 4th or 5th gears and 4th gear has hardly any power i feel like im in a prius. Any suggestions where to start?
  2. #2 Re: Problem with starting sometimes and hesitation with wot
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    what plugs did you use and did you gap them ?
  3. #3 Re: Problem with starting sometimes and hesitation with wot
    mentor
    Yeah i was just reading on here not to use iridium plugs and I think i did and also i did not gap them. what is the gap size? Could this be the reason for the starting issue too?
  1. Hesitation Problem
    By sbellmore2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2010, 01:11 PM
  2. Hesitation problem
    Last Post: 11-03-2010, 09:41 PM
  3. need help with hesitation problem
    By sbellmore2010 in forum General Tech Discussion
    Last Post: 11-01-2010, 02:59 PM
  4. Starting Problem
    By bradycat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 03:17 PM
  5. Hesitation problem
    By 4boostin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 11:41 PM
