I pulled out the front knock sensor after I flushed my coolant system. I did it to install a circulating block heater. I added an extension, and a T fitting. The knock sensor is threaded into the bottom of the T fitting and I have not had any problems. Torque to 14ft lbs and your good. It is a 22mm deep socket.
J
