Thread: Charging system failure w/HID's
Results 1 to 7 of 7
  1. #1 Re: Charging system failure w/HID's
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    how many watts are your bulbs/ballasts rated at?
  2. #2 Re: Charging system failure w/HID's
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    Each bulb is suppost to be 55 watts. So 55 x 6 = 330 watts. And that is with them all on which is actually not possible. 330 wats divided by 12 volts( should be 14.4 but will do 12 since gives more room for error). That equals 27.5 amps total. Each set is on a 10 amp fuse and none have blown. The 10 guage wire will handle the 27 amps no problem. There is no way of testing inrush voltage or amperage on the ballasts for when they first turn on. Even my high end flukemeters miss that inrush. i thought about borrowing a fluke osiloscope logging meter to see exactly what is going on. May be over kill though.
  1. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  2. Charging Sytem Failure Warning
    By 07GP316 in forum General Tech Discussion
    Last Post: 02-20-2011, 01:18 PM
  3. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
