Thread: Scanner hook up
Results 1 to 9 of 9
  1. #1 Scanner hook up
    port charlotte fl.
    Ive been dealing with a stalling problem on my 2000 GP 3.8. Ive been doing process of elemination senareo. I decide to take it and have a scanner hooked up to it. I went to two different shops and at both places there was no reading ( nothing showing ).
    They said there was a problem with the hook up on the car. Is this a fused circuit? Does anyone have an idea.
  2. #2 Re: Scanner hook up
    does it just die at random while driving or at a stoplight???
    if so that would be your crankshaft postition sensor, they dont throw codes
  3. #3 Re: Scanner hook up
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    It is indeed a fused circuit. It's shared with the passenger side cigarette light which is why it's often not working.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  4. #4 Re: Scanner hook up
    port charlotte fl.
    Ill check that fuse right now. Thanks
  5. #5 Re: Scanner hook up
    port charlotte fl.
    Not while driving. it is intermittent hot or cold. Will only idle with foot on the gas.
  6. #6 Re: Scanner hook up
    have you tried messing with the sensor's on the TB yet?
    Like unplugging the maf and or the IAC and seeing it will run better?
  7. #7 Re: Scanner hook up
    Chicago, IL
    Quote Originally Posted by john breit View Post
    Without seeing any codes I would guess a large vacuum leak or improper metering of incoming air.
  8. #8 Re: Scanner hook up
    port charlotte fl.
    The fuse was blown. I replaced it now Ill go get it scanned. THANKS
  9. #9 Re: Scanner hook up
    port charlotte fl.
    Ive replaced the IAC, MAP, TPS, PVC, removed the TB and decarboned it and the MAF.
  1. Hook up on tires.
    By shawngtp in forum Tires & Wheels
    Last Post: 10-11-2010, 11:51 AM
  2. Where do I hook up an Oil Gauge at on the moter?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-02-2010, 12:26 PM
  3. someone hook me up with a sig plz
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-28-2010, 10:41 PM
  4. aem hook up
    Last Post: 05-25-2009, 09:56 AM
  5. How to hook up the A/D inputs on the DHP Powertuner?
    By Iron Indian in forum PCM Tuning
    Last Post: 06-25-2008, 09:01 AM
