Thread: aem hook up
Results 1 to 9 of 9
gotboost3 aem hook up 05-24-2009, 03:34 PM
Bio248 Re: aem hook up 05-24-2009, 08:10 PM
gotboost3 Re: aem hook up 05-24-2009, 08:56 PM
Sabrewings Re: aem hook up 05-24-2009, 09:36 PM
gotboost3 Re: aem hook up 05-24-2009, 11:17 PM
Sabrewings Re: aem hook up 05-25-2009, 01:36 AM
gotboost3 Re: aem hook up 05-25-2009, 09:09 AM
Bio248 Re: aem hook up 05-25-2009, 09:44 AM
gixer2000 Re: aem hook up 05-25-2009, 09:56 AM
  1. #1 aem hook up
    Donating Users
    Plainfield, IL
    if i get a aem uego wideband and i got pacesetters catless would i hook up the o2 for the aem where the rear o2 goes? i have mine plugged right now im assuming yes but just making sure that i wouldnt have to make a new bung...would you guys recommend this aem with guage or getting an lc-1 and wiring it up to my aeroforce?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: aem hook up
    if you have a cat, no not the same place. you have to put it before the cat. i put mine right after where my headers exit. built my own downpipe and catback though.
  3. #3 Re: aem hook up
    Donating Users
    Plainfield, IL
    cant you just get a o2 pigtail and use one sensor?
  4. #4 Re: aem hook up
    Barksdale AFB, LA
    The PCM can't read a wideband sensor.
    I think some you can rig up the controller to emulate a narrowband to wire up to the stock wiring. You'd need to look at the capabilities of the controller though.
    2009 Subaru Impreza WRX STI
  5. #5 Re: aem hook up
    Donating Users
    Plainfield, IL
    so then if i have no cat i can put the aem's o2 in the spot for the rear o2 on my pacesetter dp? because the cat wont alter the readings.....
  6. #6 Re: aem hook up
    Barksdale AFB, LA
    That's correct.
  7. #7 Re: aem hook up
    Donating Users
    Plainfield, IL
    thanks!
  8. #8 Re: aem hook up
    the AEM setup will come with a wideband o2 sensor. you need to weld it in in it's own separate bung unless you delete the cat and run it in the rear o2 bung.
  9. #9 Re: aem hook up
    SE Level Member gixer2000's Avatar
    Braintree, ma
    He did say in his first post he had catless pacesetters. use the rear o2 bung and you will be fine
  1. Where to hook up oil pressure & volt gauge
    By 98GT3800 in forum General Tech Discussion
    Last Post: 02-14-2009, 10:26 PM
  2. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  3. How to hook up the A/D inputs on the DHP Powertuner?
    By Iron Indian in forum PCM Tuning
    Last Post: 06-25-2008, 09:01 AM
