Thread: LIM gasket
Results 1 to 5 of 5
  1. #1 LIM gasket
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Okay I'm chaning the LIM gasket on saturday and i know its been posted here before but im going to get the parts tomorrow morning because the car isnt running right now due to a broken MAF sensor. So what are all the parts i will need to accomplish this job?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: LIM gasket
    Jersey
    lim gaskets, black rtv, 6 injector 0 rings, coolant elbows, oil, coolant, s/c gasket, t/b gasket, maybe some new fuel rail connectors, mine broke one time. Your going to want to wash down the lifter valley with oil. I would also do valve cover gaskets.
    someone else will probably chime in if i forgot something
    16' wrx sti- stock
  3. #3 Re: LIM gasket
    St. Louis
    Add enough oil and 2 filters to the list. Wash the valley down w/ oil as stated, then drain BEFORE restarting. Change oil and filter using cheap oil and run for 10 min or so. Then drain again, change filter and refill w/ the good oil.
    x2 on the valve cover gaskets AND grommets.
  4. #4 Re: LIM gasket
    Donating Users
    GRAND RAPIDS, MI
    Not to thread jack but what if any sealant do you use on the lim bolts?
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  5. #5 Re: LIM gasket
    St. Louis
    I believe its a teflon based sealant w/ PTFE in it.
  1. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  2. GM Gasket Kit
    By Spartan GL in forum General Tech Discussion
    Last Post: 01-22-2010, 02:17 PM
  3. Gasket Help??
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2009, 02:21 PM
  4. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
  5. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
