Thread: having a couple issues
Results 1 to 4 of 4
  1. #1 Re: having a couple issues
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    is it jumping because the tranny is letting go of the motor or is it a running problem...if this has been happening since the plugs id guess you cracked a plug or didnt use dialectric on the wires before putting them on and now you have moisture between the plugs and wires...if not it could also be the coils but that would be a coincidence and id lean toward installation error to start
  2. #2 Re: having a couple issues
    St. Louis
    Sounds like a TCC solenoid issue. The TC is locking/unlocking. Try disconnecting BOTH battery cables, touching them together for about 30 seconds, and then leave them off overnight. Then reconnect and take a drive to let everything re-learn and see if this issue clears up.
  1. Couple ?s
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-15-2010, 12:14 AM
  2. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  3. Couple of issues I need to diagnose
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 12-02-2009, 11:20 PM
  4. Couple Issues
    By BwolfGT in forum General Tech Discussion
    Last Post: 07-29-2009, 09:45 PM
  5. COuple random cooling issues I need a little help with
    By REBELoffaLEASH in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-06-2009, 01:00 AM
