Thread: Any DIY Step By Step to Change spark plugs??
Results 1 to 20 of 83
  1. #1 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    Brampton, Ontario, Canada
    Quote Originally Posted by Gorecki View Post
    Yep, sounds like he got them switched around, fwiw, looking at the coil plug locations should be from top to bottom 632541.
    Yeah,
    It was backwards. I figured it out myself before I read your posts though (not that it makes a difference). You know what threw me off though? The black caps (not sure what they're called....if somebody knows PLEASE TELL ME) where the spark plugs connect to; the way they're ordered (from top to bottom) is :
    6/3
    2/5
    4/1
    So I assumed 1, 5 & 3 were the cylinders closest to me. Ironically, I had the first 3 closest to me right the first time, but then I changed it from 1-3-5 to 1-5-3.
    Then I posted my previous message, went back outside, and gave it the once over and thought this doesn't make sense.
    I put it back to 1-3-5, and the back row I figured shouldn't it be "2-4-6" as opposed to "4-2-6"? But the way those blacfk caps are setup is a bit misleading (in my opinion). Live and learn I guess.
    BUT.......now that the order is correct, and I know the order is correct because the power is there, I've got two new problems :
    1) The check engine light will not go off. The engine is not misfiring now, but that light won't go off. I think I need to get an OBD II / CAN scanner/code reader to turn it off and....
    2) When I accelerate, while the power is there like it should be, I hear a chirping sound. I get the impression that it's the belt. BUT....why is it making this sound now?
    Is it possible that the belt needs to be readjusted now that the spark plugs have been changed? I don't have an OBD II/CAN scanner/code reader (yet) so it's not as easy as me just hooking one up and doing the research.
    I'd really appreciate some feedback and your thoughts on this matter.
    Thanks guys!
  2. #2 Re: Any DIY Step By Step to Change spark plugs??
    the light wont just go off most of the time, you need to drive like 50 miles or so, or you could unhook the battery for 30 minutes and that should get rid of it, or ask autozone to clear it for ya.
    dont know about the chirping, maybe pull the belts and make sure all the pulleys feel good, spin freely not loose/wobbly feeling. and check the belts for cracks, could be time for a new belt.
  3. #3 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    Well I did notice a hairline fracture sized crack in the serpentine belt BUT.....that chirping sound definitely wasn't there before the plugs were changed so I'm not sure why it's making that sound now. As for the belt, I plan on changing it next week. I already knew that had to be done.
    Hopefully once I replace that, the car should be running better.
  4. #4 Re: Any DIY Step By Step to Change spark plugs??
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Quote Originally Posted by YMS1975 View Post
    Yeah,
    6/3
    2/5
    4/1
    Thanks guys!
    Already said it, those black things are the ignition coils. You'll need to get the computer reset somehow to get rid of the check engine light. It might go out on its own. Just about any corner service shop can do this, but don't know for how much. You should be able to pickup a generic OBDII scanner for cheap that'll reset the computer and clear the codes.
    That churp is probably the belt slipping. Or could be alternator, air conditioner or tensioner pully. Like I said, likely coincidence that something else needs attention.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  5. #5 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    Thanks for the clarification on the terminology; sorry must've missed it the first time you put it out there.
    I'm having a little trouble believing the chirping is "coincidence" though. But who knows? Maybe you're right. I plan on replacing the belt next week (if all goes according to plan). Once replaced hopefully that'll fix all the probs.
    Thanks for all your help!
  6. #6 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    I realize it's been a while since my last post on this subject, but after doing some research on the internet this squealing I'm hearing is most likely caused by the serpentine belt.
    I was supposed to replace it a while ago (as per my last post) but things got out of hand with my schedule. Anyhoo...I plan on replacing the alternator & the belt in one shot today. It's starting to get nippier out there. Don't know about the rest of you, but I'm from Ontario, Canada; the weather changes fast here. Right now we're in that period where each day it fluctuates. One day it's too cold the next, too hot.
    Back to my dilemma ; I tried some of that "Belt Dressing" aerosol on my serpentine belt. What a bunch of....well, you get the idea. I followed the directions to a tee and still the belt chirps (horribly).
    Anybody have any experience with belt dressing? Does it work at all, or is it just a scam? Perhaps it does work for some but my belt is so far gone that I have to replace it anyways. If anybody's used the stuff, please let me know what your experience with the stuff was like. I'm just curious is all.
    Cheers.
  7. #7 Re: Any DIY Step By Step to Change spark plugs??
    Pennsylvania
    Belt dressing is pretty useless.
  8. #8 Re: Any DIY Step By Step to Change spark plugs??
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Cheers.
    I've used it, it didnt seem to do anything, in fact it almost made the squeal worse. Waste of money IMO, could have put that money towards a new serpentine belt.
    Just out of curiosity, where aprox. in Ontario are you, Im in Ontario too. I live in Orangeville if you know where that is.
  1. How to change the back 3 spark plugs
    By fremmy182 in forum General Tech Discussion
    Last Post: 06-19-2013, 04:13 PM
  2. First step!!!
    By htown se in forum Introductions/Noob Questions
    Last Post: 03-31-2010, 12:07 AM
  3. how to change the spark plugs
    By RedBarron in forum Introductions/Noob Questions
    Last Post: 02-25-2010, 05:35 PM
  4. Next Step?
    By Bunique7 in forum General Tech Discussion
    Last Post: 08-13-2009, 10:09 PM
  5. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
