Thread: FANS
Results 1 to 10 of 10
  1. #1 FANS
    Dec 2010
    Wesley Chapel, Fla
    Its started to get very warm out, and notice that temp gauge
    goes 4 small bars from the red area. All these years I've never
    notice it going that high, coolant levels or ok when hot and cold
    in the overflow tank. I haven't heard the fans kick on yet!
    At what temp. are they kick on? I have a 2004 GTP.
  2. #2 Re: FANS
    Never Never Land
    195 i think. not 100% sure on that though
  3. #3 Re: FANS
    around 230ish both fans come on
    maybe try bleeding your system, you might have some air it, or maybe the temp sensor is going faulty.
  4. #4 Re: FANS
    Dec 2010
    Wesley Chapel, Fla
    the coolant flows flows well and did a pressure test for any leaks which
    pressure held at 20 lbs and no leaks are visible on engine or ground.
    Ouch 230 ish isn't that like to hot?
  5. #5 Re: FANS
    230 is fairly hot, but not too hot. the stock thermostat is 195* so you should probably normally run around 210*.
  6. #6 Re: FANS
    Dec 2010
    Wesley Chapel, Fla
    I bought a actron autoscanner to see what actual temps where,
    they bounce around 190 to 210 at stop or at traffic light they climbed
    to 218 i wondering what they will be in the heat of the summer, 218 is pretty
    close to the red on the dach board cluster.
  7. #7 Re: FANS
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    mine has gone as far as 3 bars from the red. fans kicked on and hasnt happened again
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  8. #8 Re: FANS
    Dec 2010
    Wesley Chapel, Fla
    thats where mine goes too, 3 bars from red, maybe it allways been there
    before and just never notice till now. I'll look into a 160 or 180 thermostat
    for it.
  9. #9 Re: FANS
    Feb 2010
    indianapolis
    mine did it right after i changed my lim and water pump so it probably had a air bubble in it and has since then burped. its supposed to be in the middle of the second quarter. have you had you coolant drained recently
  10. #10 Re: FANS
    Dec 2010
    Wesley Chapel, Fla
    about a year-n-half ago the plastic elbow under the supercharger was leaking
    had that replaced and gaskets as well, and remember burping it because the
    heater blowing hot air then going cold then hot, but that was like 20,000 miles
    ago, I guess I'll wait and see what happens when it gets real hot out.
  1. Hello GP/GM Fans!
    By PonchoJJ in forum Introductions/Noob Questions
    Last Post: 11-04-2010, 11:56 AM
  2. any NASCAR fans?
    By JarenSTi in forum Off Topic Discussion
    Last Post: 11-24-2009, 08:21 PM
  3. Hello GP fans
    By Todd0990 in forum Introductions/Noob Questions
    Last Post: 02-15-2009, 06:20 PM
  4. any top gear fans here?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-28-2008, 11:28 PM
