Thread: Losing Wideband O2 Sensors
Results 1 to 8 of 8
  1. #1 Losing Wideband O2 Sensors
    Donating Users
    South Deerfield, MA
    I have a PLX-AFR and I've had 2 sensors die in less than 4 months. PLX does not warranty sensors so I'm eating the cost of these. Anybody else had problems like this? I have it mounted about 4 or 5 inches downstream from the narrowband O2 so I don't think the position should be burning them out. Any ideas?
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Losing Wideband O2 Sensors
  3. #3 Re: Losing Wideband O2 Sensors
    Donating Users
    South Deerfield, MA
    what gas are you running?
    93 Octane E10
  4. #4 Re: Losing Wideband O2 Sensors
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    how rich are you running?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Losing Wideband O2 Sensors
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by 01gpgt01 View Post
    14.7:1 under normal conditions. 11.9:1 at WOT. I did have a few weeks after the cam install at the end of Dec that I had to work on the cold start fueling. It was running really rich for the first 10-20 seconds until settling in at 14.7:1. I know it's supposed to do that, but after the cam it got excessive. It is much better now.
    My drive to work is only about 6 miles. You think short trips like that could affect the life of the sensor?
  6. #6 Re: Losing Wideband O2 Sensors
    im not sure that short heat cycles would matter to the sensor.
  7. #7 Re: Losing Wideband O2 Sensors
    Feb 2009
    flintnasty MI
    I would probably guess there is some issues with the way it is mounted.
    Make sure that it is mounted with the wiring end pointed up in the air as much as possible (GM put that factory Ubend in for a reason). Other than that, there is no reason for it other than a rich idle.
  8. #8 Re: Losing Wideband O2 Sensors
    Donating Users
    South Deerfield, MA
    I've been exchanging e-mails with tech support at PLX. They recommend at least 24" downstream from the block for a supercharged car, mount the sensor in the top 1/3 of the pipe and point the tip of the sensor about 15 degrees downstream. I'm not quite 24" and I told them I couldn't mount it in the top 1/3 without cutting a hole in my floor or hanging my exhaust low off the bottom of the car. They replied that it was just a recommendation and to mount it as close to the top as possible. They also said it could be mounted after the cat, but that doesn't make sense to me how the reading would be worth anything after the cat. I'm going to weld in another bung a couple inches in front of the cat to give me the 24" minimum and give it the 15 degree angle the suggest. As far as being rich at idle, the narrowband and wideband would both have to be wrong for that to be happening. The only time it is running rich is at a cold start like it is supposed to.
  1. Well...looks like we're losing another dragstrip.
    By alkygto in forum The Rant Forum
    Last Post: 11-14-2010, 02:30 PM
  2. i'm losing my mind... HELP
    By hodag1210 in forum General Tech Discussion
    Last Post: 08-11-2010, 11:50 PM
  3. Losing power to wheels...
    By Deebo in forum General Tech Discussion
    Last Post: 05-01-2010, 03:06 PM
  4. losing power and stallin
    By jessica lavoy in forum General Tech Discussion
    Last Post: 03-12-2010, 02:36 PM
  5. Losing RPM Gauge while driving!
    By fuzzy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 03:01 AM
