Thread: What could this be?
Results 1 to 10 of 10
  1. #1 What could this be?
    Florida
    This mornin i start my car and let it run for a few mintues before taking my sis to school.Then just for the heck of it i rev a few times while waiting lol.I notice each time i rev, around 3k rpm i hear like a fluid sound.As if water is swooshing somewhere near the dashboard.What the hell is this?any help please.My 1st thought was a foul heater core.Car is an 01 gt 128k miles.
  2. #2 Re: What could this be?
    More likely it's from water that leaked down into the cabin air filter area. But I've never had water leak issues...so I'm totally talkin out my butthole.
  3. #3 Re: What could this be?
    Florida
    ohhh.thats possible since also every morning theres condensation buildup all on my car from overnite coolness.aight thanks bro
  4. #4 Re: What could this be?
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    It's more likely air in the coolant lines. You're coolant is probably a little low and you need to bleed the air out. Search the forum for how to do.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  5. #5 Re: What could this be?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    this
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: What could this be?
    St. Louis
    Quote Originally Posted by dmahlikGT View Post
    Is the condensation on the INSIDE of the glass? Specifically on the windshield around the defrost vents? If so, then I'd be willing to bet on leaking heater core.
    If not then yes, bleed the cooling system as there is air trapped in it somewhere.
  7. #7 Re: What could this be?
    Florida
    The air in coolant didnt even cross my mind.Thats prob it cuz when i swapped my thermostat months back i didnt bleed the air out properly lol.I was too impatient waiting for the coolant to flow out of the nipple.But now i see and i believe it is time for some extra coolant.thanks peeps
  8. #8 Re: What could this be?
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Like a few others said, air in the cooling system. Bleed it out, and have your rad cap checked. My 05 Jimmy was forever getting air in the system...the heater core would air lock completely and I would have no heat.....bleed the air, be fine for a few hours, then back to air-locked. Bled it once more, replaced the Rad Cap, been 2 months air-lock free.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  9. #9 Re: What could this be?
    im thinking air in the heater core like its been said, but the condensation, id bet if you pull up the carpet on the pass side, its all wet underneath and leaking when it rains through the blower motor as well.
  10. #10 Re: What could this be?
    Florida
    Well im gonna bleed the coolant out the nipple valve once i add more coolant.then if the problem is still there then ill have my heater core lines checked.
