Thread: sunroof not working properly
Results 1 to 19 of 19
  1. #1 sunroof not working properly
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    ok so ever since i got my 99 gtp i have had this problem.... when i hit the switch to crack the sunroof open it barely goes up at all. Than when i hit it again it goes up all the eay and slides back only about half way and stops and wont go any further. Even if i hit the switch more it wont go back any farther. Its pissing me off and i want it fixed by spring time.Can someone please help me Thank you very much
    Bryant
  2. #2 Re: sunroof not working properly
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I have another switch assembly for 30 shipped but I dont know that it is the problem
  3. #3 Re: sunroof not working properly
    Waterloo, Iowa
    well i kinda dont think itsx the switch... it sounds like a mybe a postition sensor or something
  4. #4 Re: sunroof not working properly
    Waterloo, Iowa
    and when the sunroof goes back halfway and stops... the motor makes no noise at all and nothing happens. no sounds or anything
  5. #5 Re: sunroof not working properly
    GT Level Member donmega's Avatar
    St louis, mo
    i was gona say the track but if theres no sound the motors probably going bad. mine does the same crap. but when i can keep hitting it and it will open eventually
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  6. #6 Re: sunroof not working properly
    i have a motor too
  7. #7 Re: sunroof not working properly
    SE Level Member Reddcurrlz's Avatar
    Feb 2009
    Panhandle of Florida
    I have a similar problem, but when I push the button, it pops up then makes a loud, grinding noise and stops. I'm afraid to push it in case it gets stuck OPEN. That wouldn't be good. My mechanic told me to take it to a body shop, so I did and they didn't know what to tell me. Any suggestions? I'm going to sell it in a month or so and want to get that taken care of, since I'm in Florida
  8. #8 Re: sunroof not working properly
    St louis, mo
    Quote Originally Posted by Reddcurrlz View Post
    Idk why they sent you to a body shop if its never been hit then theres no damage to casue it to twist. does the mtr still make noise when it stops? it may be the tracks and the whole sunroof frame needs replace bogus
  9. #9 Re: sunroof not working properly
    Feb 2009
    Quote Originally Posted by donmega View Post
    It's never been hit. The motor only makes the noise when I stop pushing the button. As you know, the button is pushed and the sunroof opens up; the motor stops as soon as the sunroof stops. When I push it to put it back down, it makes the same noise and stops when it stops.
  10. #10 Re: sunroof not working properly
    St louis, mo
    thats what mine does. I think theres a short somewhere bw the motor and switch idk though. i just have to hit mine again until its open. have you tried putting graphite in the tracks?
  11. #11 Re: sunroof not working properly
    Feb 2009
    No I haven't tried anything. I'm afraid if I do anything, it'll get stuck or break entirely, so until taxes get here, I probably won't try anything, but the graphite is a good idea. I have some of that. The tracks are what is opens in, right?
  12. #12 Re: sunroof not working properly
    Omaha, NE
    Bryant, I'm not sure about the 97-03's but mine does the same thing and I was told by the parts guy at the local pontiac dealer that it is most likely the position sensor.
  13. #13 Re: sunroof not working properly
    Waterloo, Iowa
    yes but where is the position sensor???
  14. #14 Re: sunroof not working properly
    St louis, mo
    it shouldbe by the module
    the sunroof control module monitors the limit switches and based on the inputs determines the position of the sunroof glass. as a limit switch closes, the 5 volt reference will be shorted to the sunroof limit switch low reference circuit, pulling down the 5 volts refrence to 0.
    the sunroof control module understands the position of the sunroof glass based on the different input combinations through the sunroof limit switch soft stop signal and sunroof limit switch open vent signal circuits
    pull down the headliner you should see the module and sops
  15. #15 Re: sunroof not working properly
    St louis, mo
    1. remove headliner
    2. remove tie strap from the wiring harness
    3. disconnect the screws from the sunroof actuator
    4. disconnect the electircal connector from the wiring harness
    5. pull straight down to disengage the drive gear from the sunroof opening positioning switch
    6. Remove the sunroof actuator from the sunroof module
    install
    1. position sunroof actuator to the module
    2. connect electrical wiring harness
    3. push the sunrooof actuator straight in the engage its drive gear into the sops
    4. install the sunroof actuator screws to the sunroof actuator
    5. install the tie strap to the wiring harness
    6. make sure it works before reinstalling the headliner as it is a pain in the *** trust me
  16. #16 Re: sunroof not working properly
    Waterloo, Iowa
    ok im sorry if someone freaks out about me bringin up my old thread but im trying to get this dignosed... here is exactly what my sunroof is doing
    2011-02-15_17-10-16_521.mp4 video by 1999blackgtp - Photobucket
    and when it stops it does not make any noise or anything when i hit th ebutton. its just like it dies, or it thinks it is all the way back. Please someone help me
  17. #17 Re: sunroof not working properly
    Houston
    Dude, really try and reset the comp. My windshield wippers got stuck in the up position and after I reset the comp, it never happened after that.
  18. #18 Re: sunroof not working properly
    Feb 2009
    Ok ya'll, I've done the following to my sunroof:
    After lubing it up with graphite,
    My son stood on the pass. side and watched it open. When it got hung up, I pushed the button again and we watched what it was doing. On the right side, it's getting hung up. When we both pulled on it to guide it back, while I was pushing the button, we did get it open most of the way YAYYYY.
    When we tried to close it the right side got stuck again, so we had to push on each side while pushing the button and eventually it closed. We tried it again and had the same problem, but it still grinds, and it's kind of intimidating ya know.
    It does not appear to be bent. Daddy suggested some WD40 then some grease (the right side has less thick grease than the left). Anymore suggestions?
    Oh, and how hard is it to remove the headliner? My car is 11 years old and I don't want it to disintegrate when I take it down.
    Thanks for all ur help
  1. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
  2. Digital display dosnt work properly.
    By XAtlantisX in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2010, 07:29 PM
  3. Rear brakes not working properly
    By mjkoester in forum Brakes/Suspension/Chassis
    Last Post: 05-21-2010, 09:31 AM
  4. What to check if your system isn't working properly
    By matt5112 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2009, 09:45 PM
