1. remove headliner
2. remove tie strap from the wiring harness
3. disconnect the screws from the sunroof actuator
4. disconnect the electircal connector from the wiring harness
5. pull straight down to disengage the drive gear from the sunroof opening positioning switch
6. Remove the sunroof actuator from the sunroof module
install
1. position sunroof actuator to the module
2. connect electrical wiring harness
3. push the sunrooof actuator straight in the engage its drive gear into the sops
4. install the sunroof actuator screws to the sunroof actuator
5. install the tie strap to the wiring harness
6. make sure it works before reinstalling the headliner as it is a pain in the *** trust me
