Thread: Seriously?
Results 1 to 15 of 15
  1. #1 Seriously?
    SE Level Member rusty prix's Avatar
    Minnesota
    So last weekend I posted about my cars issue to remain running. Reset the system and the car ran fine until this morning when i tried to start it. She sputtered but started up and died and the whole electrical system was gone. Key wouldnt come out. So I left it for the day and when I back out it sputtered and started right up for me to bring it in the garage. Then after a few minutes the electrical was out again. Battery is fairly new, and I am totally clueless. Help?
  2. #2 Re: Seriously?
    Omaha, NE
    Sounds like you have a short/ loose wire somewhere. It could even be a bad ground. Go through all your wiring, grounds and fuses looking for nics and anything else that may cause it to not operate properly.
  3. #3 Re: Seriously?
    Minnesota
    Thanks! got it figured out now. This forum is saving my life lately
  4. #4 Re: Seriously?
    Omaha, NE
    Glad I could help. My truck had the same kind of issues after my driving lights fell off. lol.
  5. #5 Re: Seriously?
    Minnesota
    Do you know if there is any way to replace the bolt that fastens the cable to the battery or do i need a whole new ground cable?
  6. #6 Re: Seriously?
    Omaha, NE
    Go to Autozone and get a new battery clamp or whatever its called. The part that goes from the wire to the terminal. It should be what you need if I understand what you're looking for. That will keep you from needing to replace the entire cable.
  7. #7 Re: Seriously?
    Minnesota
    Yea that bolt is just stripped out. I bought this car not very long ago so im finding all the cool stuff now lol
  8. #8 Re: Seriously?
    Omaha, NE
    Something like this should be an easy solution for your problem for under $10, and if you ever upgrade your audio for a sub, you can just wire it in to the same connection.
    http://www.sears.com/shc/s/p_10153_1...u=SPM677609201
  9. #9 Re: Seriously?
    Minnesota
    that isnt showing up man
  10. #10 Re: Seriously?
    Omaha, NE
    Try that link instead of the image. I couldn't find the right kind of image format.
  11. #11 Re: Seriously?
    Minnesota
    the problem is that my battery only has a hole for a bolt to screw into
  12. #12 Re: Seriously?
    Omaha, NE
    You don't have the kind of battery with external terminals then... Umm... You might have to try going to a hardware store and getting a bigger bolt and trying to make it fit, or get a new battery.
  13. #13 Re: Seriously?
    Minnesota
    so that fixed bolt comes out of the lead pretty easy then? I really want to avoid the new battery though. Money is hard to come by in highschool lol
  14. #14 Re: Seriously?
    Omaha, NE
    Its hard to say without seeing it. You may be able to get away with using a larger bolt, but if you strip the "terminal" where the bolt goes in you could have issues, but if it doesn't strip it, that could be a simple cheap fix.
  15. #15 Re: Seriously?
    Minnesota
    alright ill give it a try thanks again for all the help
