whoaaa...have u seen the price of those snap-on scanners?? jesus, I could buy another car...
You need to do an injector balance test. You said in your first post that
as soon as you added the Lucas Injector cleaner that the missfire code
appeared. I would say one or more of them are partially clogged up. If you
have access or know someone that has a good scanner to actuate the
injector balance test to see how much pressure each injector drops. Do that
first before spending any more money on parts that don't need replacing, as i know how that gets real pricey and aggravating.
^^^Funny you said that, I don't have the money this week for new injectors but I had plans of removing the injectors today and replacing the O-rings...
but yes It misfired for a long time, but never a code, added the bottle of lucas fuel injector, and wa-lah...
do u think it's a waste to remove the injectors? shouldn't there be a tell-tell sign?
Oh you already figured that out. Sorry should have read the whole thread lol
Too bad you do not have a way to test the fuel injectors? I got a set for my 04 GTP from Morad Auto parts in Ohio, they were used, but worked perfectly and not that expensive. Checking the O rings is ok, but if you have an injector that is not firing correctly that could cause a miss. If you have around 60 psi on the fuel rail and have done all you have stated and the code came up that would still tend to lead to some fuel issues as you have described. You can have the PCM flashed by GM, but I agree that the PCM cause is not the most likely possibility at this point.
I replaced BOTH the Cam Sensor and the Crankshaft Position sensor in my car. The Camshaft sensor was easier and seemed most likely at the time, but it did not fix the problem. Both sensors COULD have caused the problem I had, but it boiled down to the Crankshaft Position Sensor in my situation. The code that came up on your car was not the same issue as mine as I NEVER had a code come up at all.
Yes the Snap on Scanner is a lot of money, I would just have one put on the car to see what it says, I have done that in the past and even did it prior to changing the CPS, but no codes showed up on the Snap On Scanner at all, past or present codes. The main reason for changing the Cam sensor was HEAT affected issue. Your issue seems to be more COLD issue then heat. Both COULD cause it though I guess?
Sounds like you saturated the fuel system good with injector cleaner " Sea Foam and more " If the darn injectors are an issue just changing the o rings will not help unless you can see or smell fuel. if you have bad o rings you could see the fuel by the injectors. The injectors on a series III are longer and different than those out of an older 3800 motor.
Just for the heck of it I looked up GM 3.8 3800 Supercharged Fuel Injector P/N 12574393 L32
Item condition: Used set of 6 Price: $74.99 Plus shipping
With everything that I did to my car to try and find the problem I spent close to $ 300.00, that is with FREE Snap ON Scan and doing everything myself at no hours cost included. Yeah I have an extra Cam Sensor and an extra Fuel Pump laying around, but I feel it was not wasted money, just extra parts for later on.
You will find the problem and hopefully soon. Talking to a local GM dealer they said that they would not have been able to detect the issue I had with any of their equipment, just one of those process of elimination and reading things to finally find the issue.
If I was to bet on anything I would lay odds that the injectors or wiring is not right. The 3800 Series III is a Sequential Fuel Injection ( SFI ) motor not a Bank firing so even the wiring could cause issues also. Being as new as your car is, it is not likely to have wiring issues, still more likely some crap got in the fuel injectors and some are not firing correctly, " pulse width or pulse rate " . Still at this point it is much easier to GUESS then have proven FACT.
Yes I can pretty much agree with everything you've just stated...Injectors are not a bad way to go either but I just don't have $180 bucks for more trial and error, I've spent way more than $300 in uneccsary parts ( http://www.gmpartsdirect.com/catalog/frameset.cfm ). Next week I'm dropping it off at the Dealership and saying F it...let them put it on the machine they have, I'll pay the money this time....and if I still can't fix it, I'mma trade the darn thing in on something new insted...I love those new lacrosse's BTW
see link is crazy...ok so for supercharger injectors for a 2006 from GMpartsdirect.com are about $32 bucks a piece brand new.
Try ZZP.
probably cheaper for the injectors.
Good luck if you drop the car off at the Dealership. In my situation they had no clue on fixing the problem as the Tech 2 scanner for GM would not pick up the problem. GM here charges abut $80.00 an hour to look into things. Pulling the Injectors and just having someone who has the equipment to check them may be the better idea. You can look on the Internet and see how others have made an Injector tester. I made my own Injector tester out of another fuel rail and used a spare fuel pump and also Kerosene and a mixture for the injectors. Some say to NOT use a 12 volt battery and some say its ok. I used the 12 volt battery and never had any problems. I don't think anyone is saying hands down it is the Injectors, but the code and situation sure leads to a larger possibility for them being an issue.
and it could be...Nah our local dealership has some kind of a machine they put cars on. Just found out my neighbors fuel pump was bad on his truck that way. That same machine veried my moms old '97 Grand Am having a broke rod in the bottom end. I duno what they do but they can view EVERYTHING going on with the car while it's running, monitor's everything... plus its only $50 for that machine. There's no-way I'mma pay them $80 bucks an hour labor lol...
Yes GM has the Tech 2 scanner and it will check a lot. I don't think the GM scanner will do anymore then the Snap ON or Genesis OTC scanners except do the learn process for radios, Key Fobs etc. GM has some good Techs and are very well trained. I got my Degree in Automotive many years ago. Looks like we both may have some extra parts for a 3800 now? No matter how much a person knows or does not know, many things nowadays in modern technology requires some trial and error, even the dealerships can testify to that statement.. One thing for sure, if you have a GM facility diagnose the problem and let's say they say it is the injectors, it will be cheaper for you to do the work rather than have GM do it, BUT you may be getting so sick of this problem you may rather just have them do it and be done with it? I did a lot of checking ahead of time and TRIED to not do anything until I had good reason to do what I did, which not in all cases turned out to fix the problem.
You will get it fixed and you will " finally " be happy with the car. Gee I just spend over $600 for new Michelin Tires for my car.
Eh yeah I am about at the point where I'd rather pay the dealer bill but you know what I'm done with this car. Some guy is coming to look at my WS6 M6 today and hopefully he will be buying it, Then I'm taking the GP to the dealership for a trade in, I'mma get me a 2011 vehicle. Maybe a new Malibu, Cobalt SS, or a Chevy Cruze or something...I want a new one will all new warrenty...I'm done with this car. Thanks for the help though, but my diagnosis is over, I can't fix this crap. You keep going on and on about a snap-on scanner, you act like their a dime a dozen around here lol...In my area, just finding a hand-held code reader is dam near impossible LMAO!
Well thanks again for you help man but screw this car! =P
Goodluck and I'm glad yours is finally fixed...Happy Grand Prixing everyone!
a friend of mine has an 05 comp g with this exact problem. I think it might be the computer issue. What are people doing for a fix? Can I buy a new pcm from a good source that will have this "update". Can I just tune his PCM with my hpt to get rid of it? Doesn't seem like something I can fix it with a simple flash since while scanning I notice everything seems to be normal, then suddenly fuel trims go waaaaay negative. Please help.
