Thread: Multiple car issues.
Results 1 to 9 of 9
  1. #1 Multiple car issues.
    illinois
    Ok so yeah I'm one of those newbies and I'm hoping someone can help. I have a 98 GTP and the car will not start at allmy lights and radio work, but when I put my car in the start position nothing happens. I'm thinking possible neutral safety switch. Does anyone have any ideas or tips about swapping this out orif it may be something else going on? Also my heads-up display only works once in a while when it's really cold out. Any clue? Any and all suggestion will help! Thanks
  2. #2 Re: Multiple car issues.
    starting your own thread for these kinds of things gets you the best results.
  3. #3 Re: Multiple car issues.
    Looks like someone split off a thread for you.
    On the HUD, please check that other thread. Yes you probably need the fix.
    On starting... does your security light blink or stay on solid when you put the key in the ignition? And when you turn it? Is the battery fully charged? Do you hear a click sound in the engine bay?
    I'd suggest testing the starter first and then potentially an ignition switch. Were there any other symptoms or info leading up to this that you can give us?
  4. #4 Re: Multiple car issues.
    illinois
    There isnt a security light on the dash. I replaced the key lock cylinder, neutral safety switch, tested the "command" wire going to starter (no voltage) in any position including run position. Maybe ignition switch?
  5. #5 Re: Multiple car issues.
    Feb 2010
    N.C.
    it may be the solenoid on the starter, but you can generally hear those trying to work. It sounds like a neutral safety switch to me.
    Most people spend their entire lives wondering if they made a difference in the world; Marines don't have that problem.
    -President Ronald Regan
  6. #6 Re: Multiple car issues.
    Charles City, IA
    Check for power at both wires at the start, if you have that you need a starter.
    SMGPFC Two Nipple General
  7. #7 Re: Multiple car issues.
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    The only position you are going to have any power on that "command" or "trigger" wire is in the "START" position, so your going to need a friend to help you test that wire. Use a VOLT METER (DVOM) to test this, a test light wont tell you much, other than if there is power there. It wont tell you HOW MUCH power is there. You need at least 10.5Volts on that wire with the key in the START position.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  8. #8 Re: Multiple car issues.
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    Where in IL are you? Plenty of us around there that could help with this issue.
  9. #9 Re: Multiple car issues.
    illinois
    Thank you for all of you help! I am going to try the hud thing this weekend, but it ended up being my ignition switch that failed. I still replaced the neutral sefety switch because it wasn't looking so good. I have an aftermarket security system for some reason so I'll have to try to figure out a way to hook that back up again. Thanks for all of the feedback you are all the best!
  1. 97 GTP multiple issues
    By Ainrev in forum General Tech Discussion
    Last Post: 02-04-2011, 04:06 PM
  2. multiple issues, help?
    By Brammer in forum General Tech Discussion
    Last Post: 10-04-2010, 03:37 PM
  3. Multiple codes
    By silverstreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 12:35 AM
  4. 2001 Grand Prix GT: possible multiple issues...
    By mdurisseau in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 12:06 PM
  5. multiple misfires out of now where
    By DunriteDiesel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2008, 10:51 AM
