Thread: Rear 02 ?
Results 1 to 10 of 10
  1. #1 Rear 02 ?
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    Please don't be offended, but this site and actual Technical data don't seem to get along. I can find parts for bolting on to improve performance, but not actual CFM flow numbers and proper voltage for TPS sensors and so forth. So anyhow........
    My cat is starting to plug up and I was thinking about getting the 2.5 DP since my car is NA and has 261k on it modding is not going to happen. It gets about 1500 to 2000 miles a week put on it.
    What I am wondering…. I want the catless DP since emissions are tested here. If the rear 02 is just installed it will set a code since the fuel will be too rich running down the pipe.
    Has anyone on here used a spark inhibitor as a cap on an 02 sensor? It can be screwed into the pipe this way, but doesn’t can’t read the exhaust. Do it all the time on the Fords, but haven't even seen it mentioned here. Anyone have any information on this?
    With Fords you can put a resistor in and it ups the volts so the rear 02 reads the proper amount as well, but I can't find the voltage or how that information is shared with the PCM from this site.
  2. #2 Re: Rear 02 ?
    itll probably work just fine doing it that way. the resistor thing i dont think works, though.
  3. #3 Re: Rear 02 ?
    Nov 2009
    IL
  4. #4 Re: Rear 02 ?
    a couple people have done this with success, but the real solution is to just set the code to no report in the PCM so that it won't light up the SES.
  5. #5 Re: Rear 02 ?
    Nov 2009
    IL
    If you have the $ for a new PCM go ahead, but for those of us that don't this is a $5 solution.
    Steve at ZZP didn't care for this solution either, but he said it did work.
  6. #6 Re: Rear 02 ?
    well if you happen to know anyone with a tuner it is a free solution.
  7. #7 Re: Rear 02 ?
    Nov 2009
    IL
    This was Steve's solution. Only $60.00 and he wouldn't tell me the resistor used so I could go to radio shack and buy it for $1 and use it instead. ZZ Performance
  8. #8 Re: Rear 02 ?
    Nov 2009
    IL
    Anyone know the open and closed volt readings for those lines? That would tell me which resistor to install.
  9. #9 Re: Rear 02 ?
    the problem i have with emulators is that they die, just like o2 sensors. i ran one for a good amount of time until i just decided to run the post cat o2 sensor and call it a day.
  10. #10 Re: Rear 02 ?
    Nov 2009
    IL
    Yes, all it does is completes the circuit. Its on all the time with the ignition, so it will burn out eventually. It is a whopping $5 total for parts in that and he has it at $60. Wish I could make that much of a profit on parts.
    The more I look at that site the more Likely I am to just pull the DP and gut the cat and put it all back together.
  1. rear STB
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 12-08-2009, 01:54 PM
  2. Rear End Help
    By Juice-08 in forum Visual/Body Modifications
    Last Post: 06-03-2009, 07:13 PM
  3. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
  4. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
