Thread: How many tranny bolts?
Results 1 to 20 of 43
  1. #1 Re: How many tranny bolts?
    TDCRacing
    Guest
    ummm all i did was take 5 bolts out of the bellhousing....I have to unbolt the tc from the flexplate?
  2. #2 Re: How many tranny bolts?
    TDCRacing
    Guest
    i'm new at this but i think there are four bolts holding the flexplate on to the flywheel...so i guess i could remove those and everything should come out easy then....
  3. #3 Re: How many tranny bolts?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    How else are they to separate?
    Three bolts, I think. And the flex plate kinda is the fly wheel. You're unbolting the flex plate from the torque converter input turbine.
    What do you mean?
    I think near the bellhousing end of the tranny a bracket goes from the the tranny to the engine block. It's on the under side.
    2009 Subaru Impreza WRX STI
  4. #4 Re: How many tranny bolts?
    TDCRacing
    Guest
    Yeah thanks a lot for the help man, im used to maunals and all you have to do there is take out the bellhousing bolts and then the transmission somes out...because the Clutch is bolted onto the flywheel...At least i learned something from all of this lol....and yeah i ment flexplate to torque converter....flywheels are for manuals...
    any tips for rotating the flexplate? what about a using a prybar to rotate the flexplate...u know like moving it a little by the flexplate teeth
  1. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
  2. Tightening cradle bolts
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2008, 11:06 PM
  3. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
  4. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
