Please don't be offended, but this site and actual Technical data don't seem to get along. I can find parts for bolting on to improve performance, but not actual CFM flow numbers and proper voltage for TPS sensors and so forth. So anyhow........
My cat is starting to plug up and I was thinking about getting the 2.5 DP since my car is NA and has 261k on it modding is not going to happen. It gets about 1500 to 2000 miles a week put on it.
What I am wondering…. I want the catless DP since emissions are tested here. If the rear 02 is just installed it will set a code since the fuel will be too rich running down the pipe.
Has anyone on here used a spark inhibitor as a cap on an 02 sensor? It can be screwed into the pipe this way, but doesn’t can’t read the exhaust. Do it all the time on the Fords, but haven't even seen it mentioned here. Anyone have any information on this?
With Fords you can put a resistor in and it ups the volts so the rear 02 reads the proper amount as well, but I can't find the voltage or how that information is shared with the PCM from this site.
