Thread: no gas guage need help!
Results 1 to 3 of 3
  1. #1 no gas guage need help!
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    gas guage worked then worked crazy like, would go on full then sometimes read normal. then it just quit also the low fuel light is on all the time. i tried a different cluster out of a car the guage worked, it didnt work, tried a used fuel pump, nothing. bought a brand new fuel pump assembly still no guage. wtf! its a 01 gt grand prix.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: no gas guage need help!
    Charles City, IA
    Check your bare wires on the pcm connector, that was bryants issue.
    SMGPFC Two Nipple General
  3. #3 Re: no gas guage need help!
    Virginia
    I had the same problem on my 03 last week. I fixed it today by changing the fuel filter and now it works fine. I know it sounds igorant but sometimes its the simple things.
  1. Gas guage too active
    By jpalms in forum General Tech Discussion
    Last Post: 01-05-2011, 10:37 PM
  2. gas guage
    By 07gpx in forum Introductions/Noob Questions
    Last Post: 09-07-2009, 05:58 PM
  3. Outside teperature guage
    By mattio in forum General Tech Discussion
    Last Post: 02-15-2009, 05:00 PM
