Thread: Buying a Grand Prix Gt
Results 1 to 8 of 8
  1. #1 Buying a Grand Prix Gt
    Green Bay
    Buying a grand prix gt, a 1999-2001. Im not sure what to look for on these cars, is anything in these cars break often, are the notorious for anything?
    Also i was looking at extra add ons like some angel eyes and need a little help, never had to wire them before. So was wondering if everything i need is in this package, along with i wanna put 10k hids in them. So if anyone can help me put everything i need together for stuff for the headlights that would be great,
    i have a linke here for the lights i want, and if anyone has these can they show me a picture?
    http://cgi.ebay.com/ebaymotors/97-03...ZModelQ3aGrand
    Q20PrixQ7cSubmodelQ3aGTQQhashZitem43a51a
    06c7QQitemZ290532755143QQptZMotorsQ5fCar
    Q5fTruckQ5fPartsQ5fAccessories
    Thanks guys
  2. #2 Re: Buying a Grand Prix Gt
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    first you cant put after market bulbs in angel eyes and the instructions that comewith them are very easy to follow...they look wonderful so if you want them get them. weal points on our cars is subject to mileage of course so what specifically are you looking for
  3. #3 Re: Buying a Grand Prix Gt
    Feb 2010
    somewhere cold
    and welcome to the party new guy
  4. #4 Re: Buying a Grand Prix Gt
    Nov 2008
    Waterloo, Iowa
    I think those lights are relatively new, cause I've only started seeing them within the past year. With that said, finding someone that has them might be a challenge. There is a small picture on that link though.
  5. #5 Re: Buying a Grand Prix Gt
    its AWDsome JarenSTi's Avatar
    Hawaii
    listing has been removed?
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  6. #6 Re: Buying a Grand Prix Gt
    TN
    Welcome
    1st if you ever want speed with alittle work go for a gtp besause a gt requires a good bit of time and money to make them really fast.
    2nd The tranny is the first thing to check on any gp and then the nomal things to check when buying a used car
    88 fiero formula l67
    04 ninja
  7. #7 Re: Buying a Grand Prix Gt
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by jaren02gt View Post
    It's a broken link, as you can see half of it isn't even linked. Try this:
    97-03 Grand Prix Halo Rims BLACK Projector Headlights - eBay (item 290532755143 end time Feb-12-11 13:08:02 PST)
  8. #8 Re: Buying a Grand Prix Gt
    St. Louis
    Let's see....
    1. Check oil for signs of coolant. If you see coolant, then a good chance the LIM gaskets are leaking and need to be changed.
    2. Coolant elbows leak after age sets in. There are 2. One comes from the LIM to the tensioner, and the other is hidden by the tensioner.
    3. Cracked UIM on N/A cars. May leak coolant around the TB area. This can fill the motor with coolant and hydrolock it/break stuff.
    4. Window regulators. These are always broken. Check all the windows for smooth operation. Any slow moving windows should be suspect.
    5. Front swaybar- check the ends where the endlinks bolt to the bar. They like to crack here.
    6. Coolant condition- Pull the cap and see if it's still running the orange Dex-Cool. If so, does it look orange still or does it look rusty/Mississippi Mud? If the later, will need a flush and change the coolant out. Some go green, some put Dex back in. Not getting into that argument. Your car- you decide.
    7. Heater Core- Do you smell antifreeze in the car? Passenger side carpet wet at all? Not hard to change, just time consuming.
    8. Motor and transmission mounts. If the car has over 100K on it then I would suspect these both need to be replaced. Not an easy task if you don't have a good support system for the motor.
    9. Wheel Bearings (especially the fronts). If you test drive it and hear a growl or hum from a wheel, then the bearing is likely on its way out. May throw an ABS code as well if worn badly enough.
    10. Is the CEL on? If so, get it scanned and see what's up.
    11. Struts. Anything over 60K they need to be checked/replaced as needed. The front will just feel mushy and the rear may be sagging a bit.
    12. Transmission- As mentioned, the trannys in these cars aren't their best feature. Pull the dipstick and check the color of the fluid on a WHITE towel. If it's red and doesn't smell burnt, then it's probabaly ok. If not, then a filter change/fluid change is needed. I personally don't recommend a flush on a higher mileage tranny with an unknown maint. history. It is likely to fail shortly after a flush.
    Also drive it and see if it actually shifts into Overdrive. They are known to strip the 4th gear clutch hub out and loose overdrive. You can still drive it as a 3 speed, but wear will increase, and gas mileage will decrease. Contact Dave at TEP for trans. questions.
    13. Valve covers- These tend to leak oil as they age and can drip onto the exhaust manifolds and possibly cause a fire. Install a new set of gaskets AND grommets and you will be set.
    That's about all that comes to mind. I'm sure I'm forgetting something but that should be enough to get you in the right direction
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  3. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
  4. Buying my first Prix
    By Omegis in forum Off Topic Discussion
    Last Post: 06-08-2010, 01:30 PM
  5. Looking at buying 04 grand prix
    By RAF in forum General Tech Discussion
    Last Post: 12-26-2009, 01:45 PM
